You still have air in the brake system and this becomes evident when the operation of the booster allows the pedal to do down as it is compressing the air in the lines more efficiently than what you can do with your foot. Try starting the bleeding procedure but undoing the lines at the master cylinder and priming the unit first to get the air out of both sides of the unit. Tighten the lines and with the help of a assistant start at the longest line first and work back to the shortest. Booster failure will result in no assistance or engine stopping from a massive vacuum leak when the valves are opened. The abs is just a motor driven pump that supplies pressure to the brake system when the wheel sensors come into operation otherwise the brake pedal pressure is operating through the ABS unit to the brakes. (An ABS is only there to keep the brake pressure constant as the sensor opens and closes a valve to stop the wheel skidding . If it is not working then pressure from the pedal may bleed back leaving you with no brakes.)
try bleeding the master cylinder at the lines first as it indicates that there is still air in the pistons
loosen one line at a time and gently apply the brakes until any air bubbles come out tighten the line before releasing the brake pedal
do it for the other line and then bleed all the brakes starting at the longest line first and ending at the shortest line
THE MASTER CYLINDER NEED TO BE BLED FIRST.BEFORE PUTTING ON THE CAR.TO MANUAL BLEED BRAKE SYSTEM.YOU NEED 2 PEOPLE TO DO A BETTER JOB.YOU FIRST BLEED THE LEFT REAR RIGHT REAR LEFT FRONT AND RIGHT FRONT. WHEN YOU BLEED THE BRAKES.HAVE THE HELPER PUMP BRAKES 3 PUMPS.AND HOLD BRAKE PEDAL IN.YOU NEED A CLEAR BLEEDER HOSE IN A CLEAR BOTTLE HALF WITH CLEAN BRAKE FLUID. WITH BLEEDER HOSE ON BLEEDER SCREW AND OTHER END BLEEDER HOSE IN BOTTLE OF BRAKE FLUID.WHILE HELPER PUMP BRAKE PEDAL HOLD IT IN OPEN BLEEDER SCREW 1/4 TURN ALLOWING AIR BUBBLES LEAVE THE BRAKE SYSTEM.CLOSE THE BLEEDER SCREW BEFORE BRAKE PEDAL RELEASE.HAVE HELPER PUMP BRAKE PEDAL 3 TIMES. WITH PEDAL HELD DOWN OPEN BLEEDER SCREW GETTING AIR OUT OF THE SYSTEM.WHEN YOU SEE SOLID FLUID COMING OUT OF BLEEDER HOSE THE AIR IS OUT THE BRAKE SYSTEM.DONT DRIVE CAR ON HIGHWAY IF YOU STILL CANT GET SOLID BRAKES. HAVE CAR TOWED IN TO BE PRESSURE BLEED.
When you stand on the brakes does the pedal feel soft or hard? If soft the chances are you still have air in the system. Tighten (not too much just enough to prevent the escape of brake fluid) all the bleed nipples. Now make sure there is fluid to the maximum in the master brake reservoir. Stand on the brakes to extend all the slave pistons as far as they can go with the current situation. Starting with the the right back (as you correctly did originally) put your finger tip over the end of the nipple and undo it with an open ended spanner by only a quarter of a turn. Have a friend step on the brake pedal. When he has got to the bottom of travel push your finger hard on the nipple tip and tighten the nipple gently with e the spanner. Your friend can now release the brake pedal slowly. Again ask your friend to press on the pedal and then you undo the nipple a quarter of a turn to bleed of the fluid (and bubbles). When your friend reports that the pedal is on the floor, again tighten the bled nipple. Again your friend can only now release the brake pedal slowly. There will come a point when your friend will notice some resistance to the pedal before you slacken the bleed nipple to bleed the fluid. Keep bleeding this brake until a quarter of a pint of fluid has been pushed through and now tighten the bleed nipple firmly. Add fresh brake fluid to the brake reservoir under the hood. Now repeat this process with the back left wheel, then front right and then front left. The important thing is 1) ensure that the brake pedal is never lifted until the bleed nipple is tight otherwise air is sucked in through the nipple; having your finger tip on the end can help avoid this and 2) to ensure that the reservoir is always full of brake fluid so that only fluid can enter the system and not air 3) that you bleed plenty of fluid through the system, when you replace brake lines it is surprising just how many little pockets of air can hide in it. Good luck
1988 chevy r 3500 1 ton changed out driver front brake caliper
brakes are soft peddle goes to the floor tried to bleed but no brake fluid will come please help
the brakes have to be bleed you wrote that when you start the car the pedal goes to the floor that means the booster is working fine take it back and tell them you want the brakes bleed
