I unplug my cmos battery from the mainboard, after plug it back and try to on my computer, but cannot load windows, but show "PlatinumPAS – preboot authentication services verify please insert a valid smartcard"..... wat should i do????? i wan to try to reset CMOS, but i dont know how to do it... pls help!!!!
Dear ASHOON,
If The installer will prompt you to create an Emergency Card, a
temporary replacement of your SmartCard, in case your SmartCard
is unavailable (lost/stolen).
Note: To use the Emergency Card to regain access to Windows,
press Alt+Ctrl+E while the PlatinumSecure screensaver is running and then insert the Emergency Card. If you lose both your SmartCard and the Emergency Card, bring your computer to the nearest service center and ask them to reissue you another Smart card.
Takecare
Scorpion
I have the same problem on my 19-year-old Acer Travelmate 350TE (It was made in 2000, holy sh**t). I have also changed CMOS battery and have had this message: "PlatinumPAS: PreBoot Authentification Services Verify. Please insert a valid SmartCard".
But i haven't any SmartCard because I've bought this notebook on eBay.
So I have tried all the ways: holding for 1 minute the "Power button" after removing all batteries and power-cord. Then I have tried to boot with "Switch 3" turned on. - No effects. Then I disassemble my laptop in hope that there "shorting contacts". - Also without result. Haphazardly I've downloaded the "service manual" for my model of laptop, where was written that "Switch 3" is used for keyboard layout, not for password bypassing. But the Switch 6 was! So if all the method don't work - look forward, don't stop!
Look this page: http://robotinstitute.com/comp1.jpg
under the keyboard have a switch
I had to open the 613 up to get some fluff out of the cooling fan. After I put it all back together, I got the the same Smartcard message.
I bought the computer secondhand at an auction and it has worked fine for the last 3 years. Of course I don't have a smartcard or anything else that would have come with the computer. I called Acer and they basically told me to buy another laptop. Very helpful that was!.
Question:
How do I get this thing off. Its my computer and would like to be able to use it again.
Cheers
Addendum to previous posting:
The smartcard prompt won't let me do anything and doesn't ask for an emergency disk. If I tap any key after the 4th or 5th time it says "too many retry. System blocked"
Hi, I've the same problem, after unplugging my cmos battery thre's this message "PlatinumPAS – preboot authentication services verify please insert a valid smartcard"
Can someone help me please ?
Please email me.
Thanks
Hi, I've the same problem, after unplugging my CMOS battery there's this
Thanks
where buy smart card
my email : [email protected]
PlatinumPAS ? preboot authentication services verify please insert a valid smartcard problem
i hav sam prob but at the tim of login can u help me to omit this prob....
PlatinumPAS ? preboot authentication services verify please insert a valid smartcard problem, and notify you when a new solution is offered.
help me
