A L1 error code deals with the movement of the scanning unit. I would clean the scanning rail and re-lubricate it. Basicly the scanner can not find home postion or is timed out. Good Luck
Yes timing is everything with motors if the cylinder isn't firing at the right time all u are doing is filling the cylinder with raw fuel and dumping it into exhaust un burned it can eventually ruin you're catalytic converters also, get it professionally timed you're truck will run like a champ, unles u already caused damage.
Your F11 error code is displayed below. It would be best to have the unit serviced by a professional for this type of fix as if not performed properly, the fix could end up costing over $500.00.
F11 Shorted Keypad.
1. (F11, 12 & 13)
Disconnect power, wait 30 seconds and reapply power. 2. (F11, 12 & 13) If
fault returns upon power-up, replace EOC.
A PO174 LEAN CODE FOR BANK 2 IS THE CYLINDER BANK ON THE LEFT SIDE OF THE ENGINE (THE CYLINDERS FACING THE FRONT OF YOUR CAR)
A LEAN FUEL CONDITION COULD EXIST IF THE ENGINE IS GETING TO MUCH AIR AND/OR NOT GETING ENOUGH FUEL THIS CAN CAUSE MISFIRE, ROUGH IDLE, AND HESITATION WHEN ACCELERATING THIS COULD BE A VACUME LEAK, A DIRTY AIRFLOW SENSOR, A EGR VALVE NOT CLOSING LEAKING EXHAUST INTO THE INTAKE MANIFOLD IF ITS NOT GETING ENOUGH FUEL THE FUEL PUMP COULD BE BAD, THE AIR FILTER COULD BE DIRTY OR IT COULD BE DIRTY INJECTORS
ID TRY FUEL INJECTOR CLEANER AND A NEW AIR FILTER FIRST THEN TRY CLEANING YOUR EGR VALVE. COPY THIS LINK TO YOUR BROWSER FOR STEP BY STEP INSTRUCTIONS TO DO THIS.
www.ehow.com/how_4809842_clean-ford-taurus-egr-valve.html
IF THIS DONT DO IT I WOULD TAKE IT TO A MECHANIC TO HAVE THE OTHER THINGS CHECKED
HOPE THIS HELPS.
replace the egr valve unit.make sure u do not have a vacuum leak in the line that lead in and out of the EGR unit.the egr controls how much fuel to dump into the injectors depending on the vacuum pressure in its system.sometime to much fuel sometimes to little fuel.
