The procedure is logic and common sense buoyed up with as much information as you can obtain.
This is a typical fuel system and a tip or two:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations. (About 30 XL-12s; I defer to you)
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches. Good Luck. HTH
Lou
Testimonial: "Although I didn't get model specific help the solution was very helpful with the general ideas and is the reason my saw is fixed now. Thanx A hole lot"
what is the carb setting for a red homelite XL12
