it receives faxes but wont send tried another line no different the paper wont advance after the connection is made then i get an errorit receives faxes but wont send tried another line no different the paper wont advance after the connection is made then i get an error
Try sending to another machine and also from a different telephone line if possible.Also does this machine receive a fax.Noise on telephone line can cause such problems.
Check the electrical contacts on the cartridge as well as the inside of the unit - they may not be seated properly or the contacts are dirty. Also, check the florescent lamp that emits light for any "white out" residuals that may have accumulated on the lamp - you can check this by allowing the lamp to emit light such as when sending fax or performing a copy.
Is it when u send or recieve faxes!If on sending(open the part where u put in the faxes to sent!U will see a big black roller and under that a small black one,undeer that a long strip of glass,make sure that there's no marks of any kind on the glass!If recieving it might be on the fax that is sending the fax!Good Luck!
DR mode means that Distinctive Ring is set to on which will force your fax machine to manual receive. Turn DR off and you can set it to whatever mode you want.
There should not be a problem with TX on LGL paper. If you want to configure the machine to recieve LGL on a regular basis: Press "MENU" 1-3. Then use the up/down arrows to select LGL. "MENU", "EXIT". That should do it. Good luck!
now i am getting communication error #43
