T636400000 the unit seems to have a network connector on the rear of the machine but ordinary ethernet cables to plug in are too large.
The machine is used in a voluntary organisation and I am doing some voluntary work for them and have been asked to connect it to the internet if at all possible.
Thanks for your help.
The part number under the unit is: PN: V011932001
You probably have a Modem not an ethernet connector. To test this, try a plugging in a phone cable (RJ11). The Versa Vxi line came with one or the other, not both.
I hope this helps.
You are probably looking at a RJ-11, used for telephone (dial up - modem). You are trying to put a RJ-45 connector in it.
The RJ-45 should have 8 wires while the RJ-11 may have as many as 6 connectors.
Thank you for your voluntary work with this organization.
Note: If you were to plug a RJ-11 into a RJ-45 port and if it happened that you plugged the other end of the phone cord (RJ-11) into a phone jack --- and the phone were to ring ... you would be pumping 60 volts into your computer. Be very careful with these connections. You would then need butter and jelly for your toast, which is what your computer would be.
Ok - recap: Both look very similar ...
Ethernet = 8 conductors - RJ-45
Telephone = up to 6 wires (may be 2 or 4 also) - RJ-11. NOT interchangable.
So how will you connect? If the laptop is not builltin wireless, you can get a PCMIA card for the slot on the side that will allow wireless or ethernet. Get the card at your computer store. ... Or ... use the built in modem for dialup., You would of course need a dialup account somewhere.
Thanks for your question at FixYa.com
Please vote.
Testimonial: "Posted my problem mid-afternoon on the 17th February 2010 and had a very good response within the hour! What service. Very helpful. Many thanks ....."
