How can i remove the rear watch cover and replace the battery on a Breitling Aeromarine Colt Ocean A64350 Wrist Watch for Men?
I suggest that you got to "www.breitling.com" and after getting past the pretty pictures you click on "maintenance centers" and find the one nearest you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving.
One fairly frequent cry for help is because the owner can't get the back on again. Also since watches frequently include gaskets to keep water out, difficulty can be experienced in fitting the back and maintaining the seal.
BREITLING USA INC.
HANGAR 7
206 DANBURY ROAD
WILTON, CT 06897
[email protected]
Tel: +1-800-641-7343
Tel: +1-203-762-1180
Fax: +1-203-762-1178
In Switzerland:
BREITLING SA
P.O. BOX 1132
2540 GRENCHEN - SUISSE
Tel: +41 32 654 54 54
Fax: +41 32 654 54 00
One other note.
The COSC number generally refers to the movement number not the case number.
Inspect the hang tags that came with the watch.. the movement number may be referred to on one of them... or to the COSC certificate.
Otherwise the only way the movement number can be viewed is to remove the back.
Watches have several numbers.. reference and serial.
A - Stainless Steel
13 - Caliber
3 - Certified
40 - Model (Super Ocean)
The case will have a number the movement and the bracelet.. the crystal etc etc.
When you have the watch serviced.. have them write the movement number down for you.. for comparison.
