I believe this could be a battery,well we have the same phone and all process you take note sounds like it was my problem before.
Why is this things happening?
Battery can be easily damage due to improper usage like charging the phone while calling,listening to music,browsing etc. two current supply is entering your phone simultaneously. One is coming from the battery powered and the other is coming on the dc charger.the result, it will make your battery deform.
Just replace it a new one and for sure it will be fine again.But please avoid or minimized using your phone while on charge.To be able to preserve your battery life for long time usage.
Hope this simple guide helps you. Thank you for visiting FixYa....
the mobile requires a service with solution dipped in liquid, as few resisitors and capcitors might have been still corrosive, i think you please leave the phone without battery in room temp of 26-30 deg ... for a day or two...
Hi i have htc g1 mobile and i have a problem with the start-up when I tried to turn on the mobile the first logo was T.Mobile G1 and than it turned on to the second logo androd.after those two logo a blank screen came and near the battery it came warm and on the screen nothing happens.
I seem to be having the same problem. I finally figured out that the battery is loose and if I lay it down on it's back, the battery disconnects. Glad I have the replacement insurance as I am taking it back for a new one.
Have you tried recalibrating the battery? To do this you use the phone until it completely runs out of battery and switches itself off. Make sure it has completely run out by continuing to turn it back on until nothing happens except a red LED coming on. Then charge it while it's off until the green LED has been on for 2 hours. Hopefully this will improve your battery life.
Well try to get your hands on either a second G1 phone or a multimeter to rule out a battery issue. If you take a charged battery from another G1 and it still doesn't turn on you will have a logic board issue. With a multimeter you can measure the battery directly, if the phones doesn't turn on if the voltage is over 3.7V, you'll have a logic board issue as well. Within one year T-Mobile should give you a replacement. If you can't get a replacement under warranty there is both an T-Mobile G1 Repair Guide and a third party T-Mobile G1 Repair Service, If you try a self-repair make sure you feel comfortable with opening devices that are not meant to be user serviceable.
sounds like the red buttons have stopped working. you can attempt to reset the phone, if that fails either the button will need to be replaced, or you can contact T-mobile for a replacement given it is still under warrenty.
to reset the phone, try this:
with it OFF press the HOUSE and the POWER buttons until the phone powers up with a triangle and a yellow '!'inside. slide open the screen and press 'ALT' and 'W' at the same time. the phone should boot up as normal. if that fails, call t-mobile 1800-937-8997 for a replacement.
take the batteries out and put it back in again and try charging
check in diff power sockets
press the end of the charging cables with little amount of pressure and have a check
try to connect via the usb cable to the computer and check if it charges, if works the charger is faulty
if still did not work then it will be firmware problem with of phone
