Motorola Mobility RAZR V3xx Cellular Phone Logo
Posted on Feb 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Use the phone
I can"t open my phone , the display is black and the mess.is (Bootloader 03.02 SW Version R26111LD_U_96. Battery OK OK to Program Transfer Mode: USB )
phoenix kirkham
Level 3:
  • Motorola Mob... Master 641 Answers
  • Posted on Feb 18, 2010
phoenix kirkham
Level 3:
Answers
641
Questions
Helped
112463
Points
1352
Your phone is starting in flash mode..try and hold the palm key and the star key at te same time while turning on your phone.. that is the way u start a razor in flash mode,,mabey it will take it out of that mode
1 Related Answer
Anonymous
  • 7752 Answers
  • Posted on May 12, 2008
SOURCE: Motorola L6
you need to take the phone to a professional repair center and have the phone unlock properly.
Boot Loader 03.E0
probably you had pressed the bootloader buttons.
once the phone is diplaying a status message like you are having, it means that the phone is ready to be flashed. if you haven't do anything to your phone after displaying the message, try to remove the battery and put it back on. but if you had this status message during flashing, it will give you the same issue even if you remove the battery.
take care.
5answers
I installed a program called RAD Lite V4.1 to flash my Motorola Razr2 V9 phone to its original settings. I ran the program without incident and it stated that it was ok. Thge problem is that my phone is...
plz charge your phone for some time and try to boot. if the problem persits then you contact your vendor they will help you as your phone is under warranty
Aug 31, 2008 • Cell Phones
My v3 razor says bootloader o7.00 sw version battery ok, ok to program, connect usb data cable.. why and how do i fix this
you need to find two things the flash file for your exact software version razr and carrier unless gsm. then you need a program called rsd lite to actually flash the phone. or reload the software email me the exact screen display and ill see if i can find links to everything for you.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_156682b88afabb53
Back light would not go off so i turned off phone...when turn back on screen says "bootloader 03.08 sw version r26111mld-as-u -96.bo.ofr battery ok ok to program connect usb data cable
hey, possible reason is your celphone is corrupted,try to re open it again, if it dont work, i can only suggest is to have it fix on a celphone shop.
1helpful
Screen is locked with words & numbers on it
Your phones boot loader is corrupt.It will have to be re-flashed.
Razr v3 bootloader problem....HELP!!!
Boot Loader Problem in Moto RZR V3i.
IMEI - 35770201214927
Phone doesn't open. if turns on shows message: Boot loader A3.CC Err>A5,6935.2E Battery OK OK to Program Connect USB Data Cable it doesn't continue anywhere.
something seems to be wrong with your bootloader. what you need to do is
1. go to www.modmymoto.com and download the A3.CF bootloader which is the latest bootloader from motorola.
2. once you've done that, download the latest version of RSD Lite (you'll find it on google).
3. Install RSD Lite on your computer and open it up.
4. After the program recognises your phone, look for the bootloader that you downloaded and hit start. DON'T UNPLUG YOUR PHONE TILL THE ENTIRE PROCESS IS COMPLETE.
This should solve your problem.
This process can be risky, but it's the only way it'll work. For more information on installing the bootloader with RSD Lite, please read through the forums at www.modmymoto.com carefully.
1helpful
Interface won't come up
it is going into bootloader mode - someone did *#REDGREEN at sametime - simply take out the battery and put it back in then restart - if it's not working after that you will need to either bring it to a local repair shop or you can ship to us to do for you.
Motorola v6
re format your v6 to software...
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
