Heating & Cooling Logo
Posted on Feb 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the seer rating and tonnage of a bryant model fb4anf030
Frank Bryant Wetzel
Level 3:
  • Master 456 Answers
  • Posted on Feb 17, 2010
Frank Bryant Wetzel
Master
Level 3:
Answers
456
Questions
0
Helped
121768
Points
1116
The Tonnage appears to be 2 1/2 ton,
024=24,000 BTU=2ton
030=30,000 BTU=2 1/2ton
036=36,000 BTU= 3ton
I dont think you have the correct Model Number, Look
on the outdoor unit, the model number might start with a 38. Hint Carrier and Bryant Products are the Same, just different nametag
What seer and tonnage is a Bryant condenser unit model # 561CJ048 and serial # 4598E06708?
According to the specifications here: http://dms.hvacpartners.com/docs/1009/public/01/pds561c.18.10.pdf , all Bryant 561C air conditioners are 10 SEER. The 048 model has a 4 ton nominal cooling capacity.
I hope this helps.
LRA 55.0 convert to TON
LRA is locked rotor amperage. Has nothing to do with Tonnage. Also Tonnage is not used anymore. The rating is now called SEER
1helpful
What tonnage are unit Carrier A/C Model FB4ANF30000ACAA ?
Tonnage is not used much as a rating anymore. That model is a 3 ton. The rating used now is either BTU or SEER.
What tonnage is my new Carrier A/C model # 24ABC642A300 and how many sears is it?
The AC unit you inquired about is 3.5 ton unit. With a 10 seer rating.
Hope this information helps.
I have found this model number on the side of the AC unit outside my house and I need to know the tonnage rating. I know it is only 10 seer but can't find this info on the tag.
Did you include the make and model information?
I only see your question worded this way:
I have found this model number on the side of the AC unit outside my house and I need to know the tonnage rating. I know it is only 10 seer but can\'t find this info on the tag.
Tell us more-- or go on line and do a search for the make and model-- Can you do that?
Mack B.
I was just trying to find information on this model such as seer rating and how many tons it is
Check the model of you unit. Normally Maximum manufacturers shows the tonnage in the modewl itself. e.g........ xyz 018 means 1.5 Tr .. abc.....cor24 mni... 2TR.
Normally 12000 BTU means 1 TR. which shows as 012 or 12 like this.........
And also with amphs you can find out thew tonnage. Amphs for 1 TR under 220 vts will be maximum 4.8 amphs. If it's 1.5 TR........ 8.5 amphs
How do we use the model number to figure out the tonnage and seer rating? The model number is CKJ60-1C and the brand is Goodman
this is a 5 ton i would need more info to tell you the seer i want to say it is 10 seer due to the ckj but so many brands makes it hard to remember call 865/588-0521 ask for counter sales give that model they may ask for serial # too they will tell you all this
I HAVE A GOODMAN FURNACE GMS8 WHAT IS THE LARGEST SEER RATED AIR CONDENSER WILL WORK WITH THIS UNIT.
seer is not a problem....18 would be fine.depending on the size of the blower,you may have limitations on tonnage of the ac.
Top Heating & Cooling Experts
Paul Carew
john h
