Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Feb 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Control locked indicator on - Whirlpool Duet GHW9150P Front Load Washer
Anonymous
Level 3:
  • Master 5,911 Answers
  • Posted on Feb 17, 2010
Anonymous
Master
Level 3:
Answers
5911
Questions
6
Helped
2735750
Points
22413
The Control Lock is a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. It can inadvertently be set following a power outage, or by leaning against the control panel and usually is not an indication of a washer malfunction.
If this is a Maytag Epic, Whirlpool Duet, or Kenmore Elite, the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual. If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
NOTE: If you cannot locate your owner's manual, you can download or print a FREE copy at managemylife.com. Just type in your model number under the "Manuals" link and you will find your manual listed in a .pdf (Adobe) format.
1helpful
3answers
Loc code on my hoover tumble dryer model number hlv8dgb80
https://www.youtube.com/watch?v=kzhlvB2LjXg
Control Lock Thank you for your question and I understand your concern. The "LOC" indicates the (Control Lock). This means the control panel has been locked and it will have to be unlocked before you can use the dryer. To unlock the control panel; press and release the Option and Select buttons at the same time.
The letters (LOC) indicates Controls are Locked. To avoid having someone accidentally start or stop the washer, press OPTIONS and SELECT at the same time until the Control (Control Lock) indicator is lighted. the controls, press OPTIONS and SELECT at the same time until the Control (Control Lock) indicator goes off.
1helpful
My Buick 2004 rendevous,my door ajar light stays on and it dings, and the locks, lock and unlock a the while when driving
Probably the switch input to the BCM is bad . door ajar switch .
The BCM is also capable of commanding other vehicle systems to control functions that are not directly wired to and/or controlled by the BCM. The BCM accomplishes this task by sending specific messages on the class 2 serial data link. The vehicle system capable of performing such function will respond to the BCM message.
The BCM controls/monitors the following functions:
• Audible warnings
• Indicators control
• Interior lighting
• Exterior lighting
• Power/automatic door locks
• Keyless entry
• Content theft deterrent
• Personalization
• Serial Power Modes
• Electrical Power Management
Audible Warning
The body control module (BCM) provides the following audible control functions. Some audible control functions may be controlled by other systems through the class 2 serial data link:
• Headlamp on reminder
• Key in ignition reminder
• Personalization mode
• Delay locking indication
• Keyless entry programming/diagnostic mode indication
Indicator Control
The body control module (BCM) provides the following indicator control functions through the class 2 serial data circuits. Some indicator control functions may be controlled by other systems through the class 2 serial data link:
• Door ajar
• Liftglass/endgate ajar
• Park brake
• High beam
• Park lamp malfunction
• Service vehicle soon
• Security LED
• Battery
Door Locks Go Crazy 1
Door Locks Go Crazy 2
Door Locks Go Crazy 3
It says CONTROL LOCKED.... how do I get it unlocked??
  • Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
  • Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
  • Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
  • They designed that mostly for kids sorry pain I know just be calm feel saving some ones child thanx
    Control lock lit, no other buttons work
    Instructions
      • 1 Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
      • 2 Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off. The control panel is now unlocked, and the washer is ready for use.
      • 3 Lock the washer again by pressing and holding the "End of Cycle Signal" button until the "Control Locked" indicator light turns on.
    Read more: How to Unlock the Control on a Whirlpool Duet ' eHow.com http://www.ehow.com/how_5701217_unlock-control-whirlpool-duet.html#ixzz2HVS4i8hL
    If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
    1helpful
    I have a problem with the remote control that is not working, I have taken it local technicians but nothing . My TV is in child lock so I need a remote for the tall big telefunken TV
    Hi what you can do is to buy a universal remote control for this TV to remove the child lock. You can get that online or on any electronic shops in your area. Once done here is the instructions on how to remove the child lock using remote.
    Look at the "Power" indicator light on the front of the television to check if it is blinking. When blinking, the child lock is enabled. You can also check by pressing the "Power" button on the television.
    Point the remote control at the television and press one of the buttons on the number keypad. The "Power" indicator light will stop blinking, indicating the child lock is turned off.
    Lock the television again by pressing and holding the "Power" button on the remote control until the indicator light starts blinking. It takes approximately three seconds before the light turns on. Thanks
    4helpful
    The contol lock red light is lit and I can't get it to work
    I have a control locked alarm on a whirlpool duet washer??
    3helpful
    My duet washing machine is saying control panel lock out and nothing will come on. Any suggestions
    Problem with my cruise control and ABS light on 03 Explorer
    Anti-Lock Control —Vehicles Built After 03/2002 The 3-channel anti-lock brake system consists of the following components:
    • front wheel speed sensors
    • front wheel speed sensor rings
    • hydraulic control unit (HCU)
    • Anti-lock brake control module (ECU)
    • rear wheel speed sensor
    • rear wheel speed sensor rings
    • yellow anti-lock brake warning indicator
    The 4-channel anti-lock brake system with traction control and stability assist system consists of the following components:
    • active brake booster with integral solenoid
    • brake booster release switch
    • stability assist module (ECU)
    • stability assist event indicator
    • lateral accelerometer
    • longitudinal accelerometer (4x4)
    • rear wheel speed sensors
    • steering wheel position sensor
    • yaw rate sensor
    • brake pressure transducer
    • traction control switch
    I suspect the abs issue is causing the speed control not to work if it happened at the same time the cruise control stopped working. When the yellow ABS light comes on, it means the ABS is dactivated. You may have a faulty accelerometer which senses acceleration and yaw (side to side lean). I have not seen a bad one but you said it is sensitive to acceleration.
    I would unplug it and see what happens. The connector should have a small tab to depress so you can pull the connector out.
    Here is where it is:
    Accelerometer Removal and Installation
    1. NOTE: The accelerometer is located under the center, rear passenger seat carpet. (I think you have to remove seat for access).
      Cut the carpeting along the perforations.
    1. Disconnect the electrical connector.
    1. Remove the nuts and remove the accelerometer.
    Have dealer hook up tester and pull fault codes if you can't find an easy solution.
    Some background info
  • A malfunction in the anti-lock brake system will cause the anti-lock brake control module to shut off or inhibit the system. However, normal power-assisted braking remains.
  • Malfunctions are indicated by the yellow ABS warning indicator in the instrument cluster.
  • The anti-lock brake system is self-monitoring. When the ignition switch is turned to the RUN position, the anti-lock brake control module will carry out a preliminary self-check on the anti-lock electrical system indicated by a three-second illumination of the yellow ABS warning indicator in the instrument cluster.
  • During vehicle operation, including normal and anti-lock braking, the anti-lock brake control module monitors all electrical anti-lock functions and some hydraulic operations.
  • Each time the vehicle is driven, as soon as vehicle speed reaches approximately 20 km/h (12mph), the anti-lock brake control module turns on the pump motor for approximately one-half second. At this time, a mechanical noise may be heard. This is a normal function of the self-check by the anti-lock brake control module.
  • Pedal pulsation coupled with noise while braking on loose gravel, bumps, wet or snowy roads is normal and indicates correct functioning of the anti-lock brake system.
  • Warning Lamp Indicator
    The anti-lock brake system (ABS) uses the yellow ABS warning indicator to alert the driver of a malfunctions in the ABS.
    The yellow ABS warning indicator will come on to warn the driver that the ABS has been turned off due to a symptom that exists in the ABS. Normal power assist braking remains but wheels can lock during a panic stop while the yellow ABS warning indicator is illuminated.
    Please report back, I am curious if that is what it is. Good luck
    Mike Cairns
    Mike Cairns
    ZJ Limited
    ZJ Limited
