I dont think current wiring harness is set up for fog lights but fuse box should have a spot for relay and fuse (although it may or may not have metal leads installed) if your getting parts from ford i ask them if they have wiriring harness for it
if you decide to wire them in yourself i would HIGHLY recomend u put a relay in the system if you dont you will have to use bigger wire tho the whole sytem. with a relay u only have use the bigger wire from relay to lights. You will also have to use a heavy duty switch u will burn up factory switch if dont use a realy
Fig. Headlamps (1999) - ZOOM LINK
Check links...
Fig. Courtesy Lamps, Page 01 (1999)
Fig. Courtesy Lamps, Page 02 (1999, Coupe, Convertible/Hard Top)
Fig. Courtesy Lamps, Page 03 (1999, Convertible/Soft Top)
Fig. Courtesy Lamps, Page 04 (1999)
Hope this helps; also keep in mind that your feedback
is important and
I`ll appreciate your time and consideration if you leave some
testimonial comment about this answer.
Thank you for using FixYa, have a nice day
