I HAVE A SONY TRINITRON KV-36HS510. IM HAVING A PROBLEM,ITS NOT SHOWING A PIC, AND BLINKING 7 TIMES THEN PAUSE FOR A COUPLE OF SECONDS THEN IT WILL BLINK 7 MORE TIMES,I CAN HEAR AUDIO BUT CANNOT SEE PIC. COULD YOU PLEASE HELP ME OUT ,I'VE TRIED CUTTING THE TV OFF FOR ABOUT 6 HOURS AND CUTTING IT BACK ON,SAME RESULTS, THANKS
Hello
Your tv has problems in power regulator side, which is in the printed circuit board of the telivision. Sometimes it may due to some socket contact problems. You just contact a technician., while you cannot do it right by yourself.
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
1. Your TV has a weak picture tube, the beam current detection circuit muted the video, you may rejuvenate the CRT, or turn up screen control (located on the fly back transformer) a little it may help.
2. Other thing is that to check out is there any dry-out electrolytic capacitors in the main power supply circuit.
Hii...
Refere to Sony Blinking Codes :
5 Blinks ===> cause AKB circuit (AKB). Something is wrong with the video. check components on the C board, also check the A board. Also unit be in IK blanking, try turning up screen slightly.
I have a 36" Trinitron that keeps blinking, no picture or sound...need any kind of advice.. Do I trash it?
Hi I have same proble no sound and picture and stand by flashing 4 times, please help.....
Ameer Eysa
[email protected]
Blinking 4 flashes
