Bosch 24 in. SGS09L12 Logixx Free-standing Dishwasher Logo
Posted on Feb 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bosch Logixx dishwasher gets stuck on either wash or final rinse programme and runs all night until stopped manually. heat, pump, water supply, arms led controls all working. Any ideas as to the fault
Anonymous
Level 2:
  • Expert 457 Answers
  • Posted on Feb 28, 2010
Anonymous
Expert
Level 2:
Answers
457
Questions
Helped
126643
Points
799
You have a bad control module. send me a 4 thumbs post if this was helpful to you.p.s im a old bosch tech
Rinse solution on Fisher&Paykel dish washer not being used
Problem Possible Cause What to do Dishwasher will not start. No power. Ensure the dishwasher is plugged in and the power supply is turned on at the wall. The door is not properly closed. Close the door. Start/Pause button has not been pressed. Press the Start/Pause button . Water tap not turned on. Ensure water is connected and turned on. Blocked strainer in water inlet hose. Check the strainer and clean if necessary-it is located where the water inlet hose screws into the tap. Keylock is activated. Cancel Keylock by pressing and holding until the keylock indicator goes out. Lower spray arm rotates with difficulty. Spray arm holes are blocked by small items or food particles. Clean the spray arm. See 'Care and cleaning' for instructions. Cover of detergent dispenser cannot be closed. Detergent compartment has been overfilled. Remove detergent until the cover can be closed. Detergent dispenser is clogged with remnants of detergent. Wipe dispenser out with a damp cloth. Dry the dispenser before adding detergent. Remnants of detergent stuck inside dispenser. Compartment was damp when filled with detergent. Wipe dispenser out with a damp cloth. Dry the dispenser before adding detergent. Buttons beep and do not respond. Keylock is activated. Cancel Keylock by pressing and holding until the keylock indicator goes out. Water remains inside dishwasher after wash has ended. Drain hose is crimped, bent, or blocked. Check the drain hose and straighten if needed. Pump is jammed. Call your Fisher & Paykel Authorised Service Centre or Customer Care. Filter(s) blocked. Clean the filter(s). See 'Care and cleaning' for instructions. Foaming. Incorrect amount or type of detergent used. See section 'Adding detergent' or consult the detergent manufacturer's instructions. Too much egg in the wash load. Increase the amount of detergent. Rinse aid dosage level too high. Decrease the rinse aid dosage. Rinse aid spills not wiped up. Ensure that all rinse aid spills are wiped up when they occur. Water tap not turned on. Ensure water is connected and turned on. The dishwasher stops suddenly during the wash. Power or water supply has been interrupted. Check the power and water supplies. Knocking or rattling sound during wash. Spray arm knocking against dishes. Pause the wash and rearrange dishes. See sections 'CH and CHP models - Controls and starting a wash' or 'CK models - Controls and starting a wash', and 'Loading'. Dishes have been stacked incorrectly. Unclean dishes. Wash programme unsuitable for load. See section 'Wash programmes and detergent quantities' and select a suitable programme. Soils were too heavily baked on. Dishes may need soaking. Spray arm(s) unable to rotate. Ensure no items are obstructing the spray arm path. Dishwasher overloaded or incorrectly loaded. See the 'Loading' section. The filters are incorrectly inserted. See section 'Care and cleaning'. Detergent put in the wrong compartment. See sections 'Wash programmes and detergent quantities' and 'Adding detergent'. Excessive food not removed from dishes before loading. Scrape all food scraps off dishes before loading. Unsuitable detergent. Only use powdered or tablet detergent designed for domestic dishwashers. Not enough detergent. See 'Wash programmes and detergent quantities' for recommended quantities. You may need to adjust these to suit your particular load and the hardness of your water supply. Spray arm holes are blocked. Clean the spray arm(s). See 'Care and cleaning' for instructions. The filters are blocked. Clean the filters. See 'Care and cleaning' for instructions. Plastic items are discoloured (e.g. stain left by tomato sauce). Not enough detergent, not pre-rinsed. Pre-rinse plastic dishes before placing in the dishwasher and/or add more detergent. Alternatively, using the Rinse programme after adding dishes may minimise staining. Display flashing while Keylock is on. This is normal. The display remains on although the buttons are disabled. No action required. White stains are left on dishes; glasses have a milky appearance. Not enough detergent. See section 'Wash programmes and detergent quantities' for recommended quantities. You may need to adjust these to suit the hardness of your water supply. Rinse aid dosage too low. Increase rinse aid dosage. See 'Using rinse aid'. Dishes, cutlery have not dried. Rinse aid dosage too low. Increase rinse aid dosage. See 'Using rinse aid'. Items removed too soon. After the end of the wash programme, leave the door ajar and wait for several minutes to help drying. Rinse aid dispenser empty. (The rinse aid indicators are lit.) Add rinse aid. See section 'Using rinse aid' for instructions. Glasses have dull appearance. Rinse aid dosage too low. Increase rinse aid dosage. See 'Using rinse aid'. Tea stains or traces of lipstick have not been completely removed. Not enough detergent. See section 'Wash programmes and detergent quantities' for recommended quantities. You may need to adjust these to suit your particular load. Wash temperature too low. Select a wash programme with a higher temperature (see section 'Wash programme data' for information). Traces of rust on cutlery. Cutlery is not sufficiently rustproof. Wash by hand. Glasses clouded and discoloured; milky coating Hard water situation. Increase detergent quantities. Glasses are not dishwasher proof. Wash by hand. Water marks left on glasses and cutlery. Rinse aid level or dosage setting is too low. Ensure there is rinse aid in dispenser. If necessary, increase the rinse aid setting or try using a wash programme with a higher temperature. See sections 'Using rinse aid' and 'Wash programme data'.
Nov 12, 2018 • Dishwashers
DD603 top draw cycle getting stuck on 73min??????
Normally if you started the rinse cycle with water already in the base of the dishwasher it will immediately go into circulating the water through the wash arms. Do you hear the wash arms running when the washer is stuck at 11mins? Also when the washer is stuck at 73 mins are the wash arms running all the time or do you hear the pump operate at some stage?
If you have the dishwasher manual available make sure the water pressure setting is at HI or LO depending on your rated mains water pressure.
2helpful
E:25 on bosch dishwasher ?
Bosch E25ErrorThe drainpump is blocked or restricted by debrisPossibly something stuck/jammed in the wash or drainpropeller, remove filter mesh at the bottom of the dishwasher. Carefully remove any excess water and debris jammed near the propeller caution there may be glassor debris near or where the water drains-out.Removeand clean the spray arms, they may have food debris jammed, rinse in hot runningwaterMaintainerWash Runa wash with a tablespoon of powder, without any dishes on the hottest settinge.g. intensive, 65C, if you have a 70C this will be more effective.
1helpful
Bosch SHU 3032 dishwasher gets stuck halfway through the wash cycle and just continues to wash until you manually advance it. I turned in on before bed one night and it was still running the next morning....
It obviously sounds like a timer issue here, and as it's embedded in a big chip on the control board, I would think a new control board is needed.
The exception to this is if it is not heating at all, in which case it won't advance if the water is not hot enough. Try it again and see if it gets warm.
If not - replace the heating element.
Most machines just stop to heat up the water, but to cut down cycle time they may recirculate the wash-water first to speed things up.
2helpful
Intermittently Operating With Little or No Water
Most likely the water level detector (the sensor that tells the dishwasher to stop taking more water) is failing. It is giving early signals which confuses the dishwasher and it turns water off. Most of the time these problems are linked to grime collecting in the inside of dishwasher.
You can clean it by using a dishwasher cleaning powder. Follow instructions on satchet. YOu may have to manually fill the dishwasher before starting it. If this cleaning does not fix it, then you may have to call the technician. You may be under warranty on this (hopefully)
1helpful
2answers
Bosch SHU43C
My SHU43C is just over 3 years old. I had a similar problem recently. First, there were a few floods. Then, the Bosch only drained non-stop. Even when I used the Cancel Drain buttons the drain pump would run without stopping. When I tried to run one of the cleaning cycles, no water entered the machine. Corrective: I removed the base plate, and saw that the red plastic floatation device was in the up position. Using a flashlight and a wooden spoon, I lightly toggled the red float stem down. I pushed regular clean cycle and kept toggling with the red float stem until the rinse water started to enter the machine (turning the red stem seems to also actuate a step in the program). Now the dishwasher runs normally. Voila!
2answers
Bosch shu3036 upper arm with low pressure
check water level should just appear above filter failing that a common fault on these is the impellor wings have worn you need to strip wash motor down to get impellor cover off
2answers
Bosch Excell Dishwasher
drain pump is running all time. cause is a leak. remove bottom front panel and mop out water or can also tilt at 45deg and water shud run out. machine shud then run but you then hav to find leak
Top Bosch Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
