If its in warranty, take it back to where you purchased from. If its out of warranty, then you can remove the base from the laptop and remove the fan - goto a store to buy a new fan (if possible) - otherwise attempt to fix. Could be the bearing on the fan thats gone.
If you try to fix yourself, make sure you observe anti-static precautions.
SOURCE: sony vaio fan is making a grinding noise, how can
take it to an expert to have it checked and possible change it
The sony VGN-S460 seems to have an inherent problem with their cpu fans. It is apparent that the fan uses a ball bearing system which over time becomes worn and causes the grinding sound.
The only solution is to replace the entire fan assembly as they are inseparable.
