Bytecc 2.5 Mobile HDD Hotdrive
You don't need any specific software for Windows 2000 or above - the operating system will have the correct drivers built-in.
It should mount either on FireWire or USB (depends on which version you have - there's also a combo version).
If you're connecting via FireWire, you will need to make sure you are using a powered 6-pin FireWire connection. If your computer only has a 4-pin FireWire port, it won't provide power to the drive, so the drive won't spin up, and the system won't see it.
If you're connecting via USB, make sure you're connected to a USB 2.0 port. If you're connecting to USB 1.1, you need to connect both USB connectors on the supplied USB cable to the PC. One connector is data+power, and the other connector (the one that "branches off") is just power.
Check whether the device appears in Device Manager (hit Windows-Pause, or right-click My Computer go to Properties, Hardware, then click Device Manager).
It should appear as a hard disk drive.
Since your friend was using it on a Mac, it might be formatted as a Mac volume so Windows won't mount it as a drive letter.
Right-click My Computer, go to Manage, then click Disk Management. Either a window will pop up and ask you about initializing the disk, or an additional disk with "Unknown parititon" will appear as Removable Disk. Whatever you do, do not mess with any of the disk blocks with drive letters, especially C: as that's your system drive.
The easier method may simply be to ask your friend for format the disk as FAT32 for you. Then it'll mount in Windows and you can format it as NTFS if you need to.
