When i open my USB Drive, windows displays a message-
Please insert a disk in the drive. Please tell me what should i do.
Up to you,, if you put a flash drive into your USB port, and windows see's the drive, because its listed under my computer, but when you go to open the drive it says, please insert disk
This is telling you the flash drive has failed.
The only good thing is, if you have anything on the drive, there are programs that will extract the data from the drive so you don't lose it.
You have three options,
Extract the data that is on the drive.
Try a repair program, which can erase the drive when it tries ti repair it.
Send the flash drive to the company for repair.
Testimonial: "Thank You very much sir."
Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts if you need more help with this post a reply
hope this helps you
