To unlock it, you need the SIM Subsidy unlock code. This is unique to the individual phone and is provided by the Cell Carrier that originally sold the phone. Once you have the code from them, put your O2 sim into the phone and it should ask for the code. Type it in, then type it again when asked to verify.
After that you'll need to put in the settings for internet and mms for O2. Contact O2 and they may be able to send the settings Over The Air (OTA)
SOURCE: Bought the LG KS360 unlocked, put in the sim card
first of all 100% check thast the phone is unlocked. If your for instence putting in an O2 sim card into the phone when it's locked onto orange then it wont let you use the phone. When you say it read only emergancy calls is this becasue you have no credit ?? and finally theres a good possibility that either 1. the sim card is faulty in which case just ring up the sim card provider and they should happily give you a new one. 2. tThe sim card reader is broken in the phone in which case your going to need to either send t bak to the place you got it from or ring up the company. hope this helps
SOURCE: need unlock code for lg ks360 mobile phone
Hi Friend,
Kindly follow the instructions in the below mentioned link and you can find by your own the unlock code
http://www.pb4kn.co.uk/ks360_unlocking.htm
If this is helpful and solved your problem kindly rate this
Thanks for using Fixya
Regards,
Ayyasam
SOURCE: put sim card in brand new LG KS360 and it reads rejected by netwo
that means that your phone is blocked.u have to go to a phone service and ask them to unlock your phone.it's probably something around 20-25 euros
SOURCE: unlocked lg KS360 wont unlock
Have you activated your phone? When a phone hasn't been activated, it goes into an emergency call only mode.
