Question about HP Compaq Presario V2000 Notebook
Wlan disabled do not know why but my computer does not work wireless sometimes. It seems no devices are set up at all. my problem is not in the network that is not detected by my computer. It seems the wireless functionality does not exist in my laptop at all even if it did work before. Also, get the message on HP WIRELESS ASSISTANT: as disabled, but when i go to the device manager there is no way i can solve it... please let me know how ot solve this problem thanks
  • 4 more comments
  • Anonymous Jul 09, 2008
    wireless wlan disabled
  • Anonymous Aug 16, 2008
    I have the Compaq Presario c700 and when i press the wireless buttons it just says disabled???? Then it wont recognize anything??
  • manda12588 Oct 05, 2008
    I have the same problem. I have the Presario v6000,and whenever my laptop goes to sleep,it comes back and suddenly the wireless switch is disabled. when i go back to the device manager to turn it on,nothing works to turn it back. help please?
  • badvista Mar 08, 2009
    I have HP Pavilion dv3-1075us Notebook PC. Brand New
    Runs Vista home premium.
    Same issues with WLAN off/Disabled, only There is no HP
    Wireless Assistant System Icon in System Tray.
    Reinstalling WLAN Drivers didnt work.
    Trying the "Toggle" method above didnt work either.
    Tried Re-installing HP Wireless Assistant From Recovery Manager.. no dice.
    -tried disabling both the Broadcom4322AG 802.11 a-g/draft n Wi-Fi adapter and The REaltek RTL8168(p)/8111C(P) FAmily PCi-E Gigabit Ethernet NIC and re-enabling .
    Wireless icon on keyboard only is able to turn WLAN Disabled or OFF.. no ON...
    i have other machines able to connect to internet wirelessly to router.. np.
    Need a little help...
  • zeeshanciit Apr 11, 2009
    hp dv5 1000us
    my wlan option remain disabled, and there is noway to on it. kindly help
  • shihabsultan May 11, 2010
    Just signed in to say thanks to hobbes2120. It worked like a  charm. thanks again.
  • 35 Answers
If you have vista click the start button and in the start search type "hp wireless assistant". It should show up in your list while you type it. Click on it. Once the assistant box shows up, click on "properties". A "settings" box should show up. The main one you need here is "independant controls for installed wireless device". Check that box. The other ones are icons and indicators that you can check at your discretion. If in doubt, check them all. Hit the "apply" button. Then in the upper right hand side of the box hit the button that says "turn on". This should activate the device and if you have a light up indicator on your computer, it should change color or light up. That should do it. Kind of weird how it gets to that point.
Posted on Mar 31, 2009
I have a Presario MR2305NR with a similar problem, I went so far as to reformat my hard drive and reinstall Windows & drivers. WLAN still disabled! The solution turned out to be so easy:
  1. Toggle wireless button on notebook (that's the one that is supposed to light up blue when it's working). Note how in one position, pop up screen says "HP Wireless Assistant WLAN: Off." In other postion, pop up screen says "HP Wireless Assistant WLAN: Disabled."
  2. Toggle wireless button again so pop up screen says " HP Wireless Assistant WLAN: Off."
  3. Double click on HP Wireless Assistant icon on tray. HP Wireless Assistant screen appears. Button on screen says "Turn On." If button is grayed out so you can't click on it, toggle wireless button again.
  4. Click on the "Turn ON: button. Button now says "Turn Off." Pop up screen now says " HP Wireless Assistant WLAN: On" and it is working again!
Posted on Feb 18, 2009
  • David Sep 13, 2012
    I needed to go to device manager and "enable device" there. Turns out the system disabled it due to a conflict.
  • 100 Answers
First u check the whether u wlan switched ON or OFF.If ur laptop have Windows vista operating system then u click on start button,Programs,Recovery Manager.In recovery manager,u click on recovery Hardware driver reinstalltion page.There u select YES and click on Next button .Its shows the drivers lists.There u select the Wlan drivers and click on Next button.After installation completed,u restart ur laptop and check it.
If u r living in INDIA.Then u go for this website address
www.hp.com/in/support
Toll free No.1800 112 267
Posted on Feb 26, 2008
  • 520 Answers
Usually in device manager you just right click wlan and enable,you can also go into control panel,network connections and enable it there or right click on the icon in sys tray and enable are you sure its disabled and not too weak signal to connect
  • Anonymous Feb 26, 2008
    you could also try uninstalling wlan drivers and reinstalling just in case there maybe resource conflicts
    New Friend:
Try to deinstall wlan in device manager and restart computer /download latest wlan drivers from the intel site and install them / or try to examine control panel with wlan button, it can stuck, in that case wlan always be disabled
Posted on Nov 08, 2009
    New Friend:
Hug Plug Dual Wall Outlet Adapter Electric Green
Posted on Jul 10, 2014
    New Friend:
Hobbes2120 many, many thanks. The best solution.
Posted on Jun 13, 2010
Thank you so much - I thought I would never find help
Posted on Aug 26, 2008
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 56 Answers
Dv6146eu is a trouble mashine, has tempt problems when working in ordinary houses with lots of cats and dogs, temp raises and above, are bottons to turn on mashine and sound, which will problely stop these systems, having worked with the mashine for so long I think I can narrow it down too that. the bios if you try too change it will also stop the wireless.
Posted on Jun 14, 2010
SOURCE:
I am having trouble getting access to a ruckus router network. It doesn't have any numbers or codes I can see on it. My wifi shows several networks. None named ruckus. I don't know which to connect and I...
Several things could be a problem. First, not all wireless networks are visible, even though they are active. I have no idea what you're trying to connect - a phone, tablet, laptop, TV, or ? sometimes you can type in a network name and then it will ask you for the password or passphrase. to try this, look at your friend's device while it is connected and be sure to type the wireless network name exactly like on his device. Another possibility is the wireless router is putting out a signal your device cannot connect to.
Nov 04, 2017 | The Computers & Internet
How to change host on mc9090
Wireless Local Area Networks (WLANs) allow mobile computers to communicate wirelessly and send captured data to a host device in real time. Before using the mobile computer on a WLAN, the facility must be set up with the required hardware to run the wireless LAN and the mobile computer must be configured. Refer to the documentation provided with the access points (APs) for instructions on setting up the hardware. To configure the mobile computer, a set of wireless applications provide the tools to configure and test the wireless radio in the mobile computer. The Wireless Application menu on the task tray provides the following wireless applications: • Wireless Status • Wireless Diagnostics • Find WLANs • Manage Profiles • Options • Enable/Disable Radio • Log On/Off Tap the Signal Strength icon to display the Wireless Applications menu
pg 1-13,
Download manual
Apr 07, 2015 | Symbol Motorola MC9090 Mobile Computer
My wlan (function/F10) key doesn't work/light stays amber!!!!! No wireless internet/Internet only works when directly plugged into PC.
Check in device manager for the wireless card. Right click 'my computer' select 'properties' click the hardware tab and device manager, it should be listed as a network device. if it's listed update the drivers, it may just be disabled in windows. If it's listed as installed and working correctly in device manager it may be faulty.
you can also try running 'cmd' to lauch the command prompt and typing "ipconfig /all" this will show all available devices in your computer and their state.
Good luck.
Apr 22, 2012 | Compaq Presario Notebook
I need to set up secure access for 3 computers, HOW?
if your connecting all your computers wirelessly then you can setup encryption for your wireless network.
login to your router from a browser. go to 192.168.1.1
click on wireless
click on wireless security
set security mode to wpa2/wpa mix mode.
set the passphase. this will be the password you required to authenticate to your wireless network.
click save settings.
all wireless devices will need to be reconfigured to the new passphase/password in order to use your secured wireless network.
Feb 14, 2012 | Cisco Linksys E1000 WirelessN Broadband...
Cannot connect to wireless connection using the router c150brs4
There might be many reasons for this. However I always prefer to begin by simple tiny things. Make sure that the router is advertising itself, there something called SSID (service set identifier). The SSID differentiates one WLAN from another, so all access points and all devices attempting to connect to a specific WLAN must use the same SSID. A device will not be permitted to join the BSS unless it can provide the unique SSID.
to make the long story short , SSID is the method of knowing that there is a wireless coverage in a certain area. sending SSID sometimes is considered unsecure. Therefore you have an option of disabling SSID broadcasting. Therefore I suggest to make sure that SSID broadcasting is enabled on your wireless router and then sarch for your wireless network.
One other thing make sure that your router is using a WI-FI technology (802.11b, 802.11a or 802.11g) that is supported by the wireless Adapter (Card) implemented on your laptop..
thanks.
May 03, 2011 | Office Equipment & Supplies
My m105 works great but will not hold a wireless connection. Please advise....Allan...
Hello
Disable firewall settings to check if it doesn't block connection.
1) Update the WLan driver. In most cases this solves connections issues.
http://aps2.toshiba-tro.de/wlan/
2) Go to device manger -> WLan card -> Properties -> Advanced tab and check if the WLan modus 802.11 B/G or N has been set to the same Wlan modules supported by router!
3) Disable the WLan encryption and password on the router and check if you could connect to the router without any security settings. Do this only for testing purposes. If it connects properly, enable the encryption password and try again.
4) Disable WLan power saving! This can be done in Win Power Management. If that doesn't work, perform a system restore, set your computer to how it was the last time you were on the internet.
Apr 15, 2011 | Toshiba Satellite A105 Notebook
I have a dell inspiron mini with a dell wireless
Go to system restore and set the computer back to the day before the problem started...try that and let me know if it solves your problem:)
Apr 13, 2010 | Computers & Internet
My new laptop with Windows7 OS cannot connect either wireless or direct cable to DLInk DI624. I have tried turning off my firewall but still same problem persist. The router is working fine with my old pc...
Adding a wired computer or device to the network.
If you router is already set up and you want to add a new computer, you don't need to run the set up CD for the router again.
If you are adding a desktop or any other device to the router which will always be connected to the router with the Ethernet cable, then in this case you don't need to do anything.
You can just connect the Ethernet cable between the router and the computer and it should work.
If you are not able to go online even when it is connected properly then check IP address of the computer.
Adding a wireless computer or device to the network.
If you want to add a new wireless device ( laptop or any other wireless device) to the network, then you should know all the wireless settings of the router. What wireless settings do you need to know ?
You should know the wireless network name ( SSID ), wireless channel and the wireless security password
( network key ). Once you get all the wireless settings of the router , you will need to connect to the wireless network on the computer. when you try to connect to the network , you will see your wireless network in the list. You just need to select your network and connect to it. If it is secured then you will need to enter the network key and you will be able to go online.
To check the wireless settings of the router , you will need to access the router set up page. On the set up page you will find all the wireless settings of the router.
click Here for step by step instructions
Dec 30, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
I have a belkin router set up in my home and I just purchased a 2nd laptop but I am unsure how to add this new laptp to the connector
Click Here for step by step instructions
Dec 27, 2009 | Belkin (F5D7231-4) Wireless Router
I misplaced my cd to connect my other laptop to the wireless router, WRT54G, and I'm trying to get it through your site
If your router is already set up and you want to add a new computer, you don't need to run the set up CD for the router again.
Click Here for more info
Dec 19, 2009 | Linksys Wireless-N WRT150N Router
HP Compaq Presario V2000 Notebook Logo
17,703 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
