Blaupunkt Heidelberg CD51 CD Player Logo
Anonymous Posted on Feb 16, 2010
Need rear panel drawing or install instr for Heidelberg CD51
I have a Blaupunkt Heidelberg CD51 receiver in my car. I just bought the Aux 1 adapter cable that plugs into the rear Aux 1 8-pin DIN connector. I can't see the back of the receiver when it is mounted in place and need either (1) a drawing of the rear panel or (2) instructions on how to remove it from the dash so that I can plug the cable in. I have the operations manual already but it does not contain either of the above.
Any assistance is appreciated!
Anonymous
Level 1:
New Friend:
  • Contributor 56 Answers
  • Posted on Feb 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
56
Questions
0
Helped
24626
Points
97
Crutchfield has the manual available for download here:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/023/023HDLCD51.PDF
I saw a picture in the manual showing where the various connectors plug in. You should be able to tell from there what the orientation should be. It was page 29 of the PDF.
Testimonial: "Thanks very much for the information. This is a more complete version of the manual than the one that I have, and it contains the information I need. "
Won't eject CD
well the owner manual says to press button 9 and then flip down the face of the radio and it eject the cd. not just flip the face down . here is a link to the eject instructions..how to eject the cd on a miami beach cd51 have more questions email me at [email protected]
1helpful
Volume cannot be controlled
Do you mean the volume knob or as you might call it wheel doesn't work? If so, the least expensive thing to do is to take the face apart, remove the whole volume wheel mechanism (you will need to unsolder to clips) and take that apart, then clean the dust off and anything that gets in the way, then put it back together and solder it back. I've had the same problem, fixed it in under 30minutes, didn't cost me a cent.
1helpful
My Blaupunkt, Heidelberg CD51 car stereo beeps every minute or so, whether you're listening to the radio or CD's? - HELP please
That normally means that it requires the  security code to be entered.
Disconnect the fuse for 10 minutes, replace then enter the code.
If you do not have the code then the radio will have to be removed from the dashboard and quote all the letters+numbers on any labels, barcodes or stamped in the metal casing.
Also quote the make of car it is fitted into.
Blaupunkt antenna connection !
Yes - adapters are available in stores & online. Try here:
http://www.bluespot.co.uk/install.asp
6helpful
3answers
BLAUPUNKT GMDAT CDP 3 (E) - CAR RADIO CD HOW TO EJECT CD?
Hi graz,
If your unit has a SRC button to the right of the CD clot, try holding this down for a few seconds - works on mine!
2helpful
3answers
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
