HP Photosmart C7280 Printer Logo
Posted on Feb 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Power went out last week. Can't print. The jobs
Power went out last week. Can't print. The jobs show in status on pc but don't reach printer. All other functions of HP Photosmart are working (fax, scan,copy)
electronic & computer repair& servicre
Level 3:
  • HP Master 12,061 Answers
  • Posted on Feb 15, 2010
HP Master
Level 3:
Answers
12061
Questions
0
Helped
4007902
Points
36390
OK try this Remove Power Cord from Printer, remove USB cable from PC. Reboot PC. Wait 10 mins, then connect, the Power again to printer. Turn OFF PC. While OFF plug in the USB cable TO any other USB other than the one used before. Turn PC ON. After a bit you should hopefully have a working printer. If that doesn't work, Unplug USB, reboot & then using your DVD re-install it all again.
Email not reaching destination but says "job complete"
Check your mail server SMTP port 25
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Riso Rp3700 won't print from computer
We suffer the same issue. Have you find the solution?
Shows printjobs on printer but not in queue
Hi
Try disconnecting the printer from power and from the PC completely.
Reboot the PC.
Connect the printer again and then try printing.
Solved?
Uninstall and re-install the printer again.Don't have installation discs?
Download the drivers from the link below,Just select your Operating System,
h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=295932&lang=en&cc=us&prodTypeId=18972&prodSeriesId=295930&taskId=135
Hope it helps.
In "printer details" it shows a document with a
Try turning your PC,and the printer off and disconnect them from power.
Reconnect them again and turn them on.
Check status of the print job now.
Hope this helps.Thanks!
Please rate this answer.
2helpful
I replaced the cartridge of my hp psc 1401, copied the test page that was automatically printed, but now I can't print anything. Copying works OK. I don't get an error message or blinking lights on...
what is the status of print job in the queue? whether it is showing printing or no status in the windows.
if the status is printing you delete all the print jobs and switch off and on .then try print something. if no status is there in the windows then you check whether the printer is off line .try make it online by right click on the printer icon then click on the use printer online.
Trying to print a picture from my dell computer. when i hit print on the computer printer does not print. what button do i push on the printer itself. when i go to view/print it just says to insert memory...
With the printer power on, unplug and then plug in the printer from/to the computer. This should force the printer to be reinstalled.
Check the printer status.
Click START>Control Panel>Devices and Printers>click on your printer. check the status for any error messages. On the printer status, delete all pending jobs. Once the printer status display shows that all pending jobs have been deleted, retry printing.
Let me know if printing is reestablished. Thanks.
2answers
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
The green power button blinks continuously and the printer will not print any type of job. The last job printed was very clear so I don't think I need a new ink cartridge. The status of the printer shows...
ya u need now inkjet cartridge or ur printers card dead 1st chack put black cartridge in ur printers and color cartridge out then see green light blinks if blinks black cartridge out and color cartridge put in the printers then u know thanls
Trying to print, but Status Paused is showing
Hi
Thanks for using FIxYa. Please turn the printer off and then cancel all the print queues pending in the bottom toolbar by double clicking on the printer logo if you want to delete all the pending printing files. Now turn the printer on. If you do not want to cancel all the printing jobs then you can double click on the printer logo showing in the right side of the bottom tool bar and then right click on the printing jobs pending for printings then click on restart printing. Issue will be resolved and it will not show ‘paused status’.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
2helpful
My last print job gets stuck deleting in the queue!
Go to C:\Windows\System32\spool\PRINTERS on your PC and you will see two files listed fior each of the outstanding print jobs. These will have the file extensions .SHD and .SPL
You need to delete both of these files then power off and power on your printer to be able to continue printing.
k24674
Grand Canyon Tech
Grand Canyon Tech
