tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Lamp of TV getting weaker and requires replacement. This shut off by itself will increase day by day until you put new lamp in TV.
Always Buy Sony original lamp and avoid aftermarket/ cheap lamp for TV safety.
Is your air intake clean or clogged.. Maybe it's overheating causing it to shut off.. Had the same problem didn't replace the bulb but cleaned the intake and it works great again. Worth a try.. Intake is located on the left back pannel of the tv.. outside pannel pops off easly.
Followed Terryfic's solution. I am a DIYer and managed to order the part, desolder the old one and solder in the new one. However, when I turned it back on I got a black screen with sound. Hmmm, saw the adjustment screws but was hesitant. Ended up turning about 10 degrees one way and presto chango... Saved a $1200 upgrade to HD for a $30 part! Thanks
