Computers & Internet Logo
Anonymous Posted on Feb 15, 2010
My hp2009m monitor goes into sleep mode
I have a hp2009m flat monitor and hp media specialist tower, my problem is that every thing works fine until we shut them down, the tower works but the monitor says it is going into sleep mode and then the screen goes black. We have another tower that we can plug the monitor up to and it takes off and works fine. So I am thinking that I have a problem with the port that the monitor plugs into. Can I replace just that port, or how do I fix the problem?
  • 1 more comment
  • Anonymous Feb 22, 2010
    When I restart my computer the monitor says that it is going into sleep mode, then can't wake it up, no matter what we do.
  • Darrell
    Darrell May 11, 2010
    You've said that you tried the hp monitor on a different computer and the monitor worked fine. You might try a different monitor on the HP computer to see if it is in fact the serial port on the computer. If a different monitor won't function then it is possibly the port. On a lot of motherboards, the video port is hard-mounted meaning you can't simply unplug it and plug in a new one. However, you may be able to buy an after-market video card and place it in an open PCI slot and just bypass the on-board video.But I wouldn't go that far until you've determined for sure that the problem is the port.
  • Darrell
    Are you saying that, when you shut the computer down the screen displays the message, or after you restart your computer, the monitor continues to show that it is going into sleep mode?
Jta91
Level 2:
  • Expert 99 Answers
  • Posted on Feb 24, 2010
Jta91
Expert
Level 2:
Answers
99
Questions
0
Helped
49693
Points
231
Monitors are programmed to go to sleep when there is no input. If you shut it down on the other "tower" also it will do the same. You need to physically hit the power button on the monitor to actually shut it off.
Monitor immediately goes to sleep. Tower shuts down from unplugging it.
have you tryed starting up in safe mode to see if you can get into your windows?
I have an HP 2709m full lcd monitor and it shows osd lockout and I dont know how to unlock it. Ive tryed doing it with the menu with know help. I have to shut it down and then turn it back on and it works...
the manual say push the menu button for 10 seconds, and it unlocks.
sleep mode too go in and turn off power saver
its clock timer that and goes to sleep on time inside the monitor
why not read the manual costs nothing to read
at hp
http://h10032.www1.hp.com/ctg/Manual/c01725831
read page 25
and then read
page 27
amazing no, books, yah, books are so OLDSKOOL
3answers
My monitor has kicked into sleep mode and won't "wake up".
Unplug all the Cables from Compaq Presario 5103 CL and leave the Keyboard, mouse and monitor cable pluged in.
Now make sure the power cable of the monitor should be pluged in and the power cable of the tower should be pluged in.
Now to check if the montor is fine just unplug the video cable only which will show no input signal on the screen. If it shows this signal the monitor is fine. Plug back in the video cable.
If the monitor is going to sleep mode it might be possible that the old computer ( Compaq Presario 5103 CL ) is in stand by mode. hit any key on the keyboard and it should come back .
If it is not in the stand by mode then do one thing. Check the same monitor with the new computer. If it is working. Perfect ..!
Do one thing now ..!
Unplug all the cables from your old system and then press the power button for 30 sec and let it go. Now plug the keyboard, mouse and the monitor try again.
If it works Perfect. If not ..!
Then you need to open the tower and check on the processor FAN is it running..? If its not running you will not get the display as the fan is responsible for the display on the screen. Otherwise...!
Check the Tower possibly the Tower is not getting the power.
Try these steps and let me know If it works
1helpful
I have had problems with communication between the tower and the monitor. I recently bought a Dell flat screen monitor. The monitor worked for about two months, now when it is turned on, it immediately...
Sorry it IS the monitor this is a common problem, unfortunately, this is evidenced by the fact it still didn't work when connected to another machine,regardless of lack or message. Do a warranty claim.
I have a hp2009m flat monitor and hp a1473w
everything seems to be working as normal.. that is just a message and it happens with some of the monitors.. you don't have to worry about it..
Mx75 monitor turns off when I awaken my computer
right click on desktop select properties(screen saver ) select monitor button in that select turn monitor never.(configure carefully)
Hp flatscreen monitor won't come on when i boot my computer
it sounds like your graphics card is conflicting weith your flatscreen , i had a sony desktop do the same thing only on a TFT or LCD monitor , you may want to get a better graphics card , my bet is its probly an intergrated one .
1helpful
Hp L1706 Monitor Keeps Going Into Sleep Mode
I have an hp media center that runs windows xp with service pack 3 and my monitor is an hpL1706 monitor and was running fine now it says no input and goes into sleep mode how do I fix it?
No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
  • right mouse click on the desktop
  • select graphic options
  • output to
  • extended desktop
Maybe some changings/modification will help you too.
Stefan
3helpful
2answers
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
