There's no fuse problem with that computer, try this first, Plug in the charger to an outlet don't plug it in the laptop, if the light on the charger turns on, then the charger is working try to plug it on the computer if the light on the charger goes out there's a problem with your motherboard. Contact the tech support for that so you can get that part replaced.
To double check try to use a known good charger if it works then you'll need another charger if not, Then contact your tech support for your dell make sure you still have a warrant.
Hope this helps!
