Dell A940 All-In-One InkJet Printer Logo
Posted on Feb 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello sir, My dell A940 printer cadridge finished i have refilled when i start printing the paper the words are not correctly printing but it has been printing in shaded type. kinldy tell me what to do. Regards, Javid ahemed
  • Anonymous Mar 13, 2014
    Has just started printing all words in bold, with desired bold even blacker. Have checked all settings and bold is not marked.
Alun Cox
Level 3:
President:
  • Master 2,679 Answers
  • Posted on Feb 15, 2010
Alun Cox
Master
Level 3:
President:
Answers
2679
Questions
0
Helped
689381
Points
8444
When you refill a cartridge you must leave it to expell any airlock. 2Hrs should be enough.
Print problems with A940 dell printer
The print-head pulls ink from the ink-cartridge, and sprays it onto the paper, unless the print-head has become "clogged".
Run a "print-head-cleaning" cycle, to try to unclog it.
Dell A940 printer will not pull down,or start
I got it fixed........But if I told you how...I would need to charge you $6.95 per month.
1helpful
2answers
The color red will not print on My Dell A940 printer.
Try find another printer(same model- says printer B)...take printer head from printer B to your printer(says printer A),use your ink cartridge and test your printing....if all color seen on paper, then the problem is your printer head, to make sure is it true or not, use printer head from printer A into printer B.see the result...
DELL A940 NOT PRINTING.
Normal 0 This doesn’t help fix all printers because each situation is different and in most cases we don’t have enough information to determine the fix. So hope this will provide some help.
Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
1helpful
My Dell A940 is not printing with black ink.
how long have the cartridges sat? I've noticed after about a week, that dell ink clogs up. Also, Lexmark makes most Dell printers. In my time as a cartridge refiller, we blow through dells and lexmarks and when they **** out, usually it acts like it prints, but nothing comes out printed, only blank pages
1helpful
5answers
Dell all in one printer 940
try holding the power down for 15 seconds
2answers
Black cartridge not printing
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
1helpful
Dell A940 smeared printing
Our Dell AIO A940 stopped printing black ink (it went throught the motions but he paper came out blank). Finally got it to print by selecting:
Maybe it will work for you! Good luck!
Dell A940 Color Ink Problem
Do check the option and make sure that you have not inadvertently set it to black only- This could be computer wise or on the A940 panel. If you are sure all is well here Remove the scanner software and reinstall. Email Dell to See what they have to say
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
