Sharp XR-10S DLP Projector Logo
Posted on Feb 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1-Projector is in standby, so I hit the power button. 2-Green power light comes on, and lamp light flashes green (warm-up). 3-Lamp light goes solid green, but no picture. (However, if you look at the lens, you can barely make out the image, .) 4-Faint lens image goes away, and lamp light blinks green again. 5-after about 7-8 repetitions of this process, the lamp light starts blinking red, and power light blinks green. Finally, both lights go red, and projector does a bit of cooling, and reverts to standby. Lamp use was approx 400-450 hrs at this point. What is wrong?
Anonymous
Level 2:
  • Expert 233 Answers
  • Posted on Feb 15, 2010
Anonymous
Expert
Level 2:
Answers
233
Questions
0
Helped
72272
Points
588
I think it's capacitor issue on the power supply board. open it, look for power supply board and fine bloated capacitor and replace it.
1helpful
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Hello. My Nec LT35 projector will not turn on. From standby mode, I hit the power button, the power LED turns green, the fan starts, but after two seconds it switches back to standby. The...
i have the exact same error with same projector. did you manage to solve this?
my status led blinked red 6 times indicating a "lamp error" which wasn't helpful. i also tried removing and replacing lamp but didn't work.
2answers
5helpful
Optoma 719, can't get lamp and fan to turn on.
There is a stuffed 10v 3300uf capacitor on the power board. You need to replace it.
Bellow you can check in the picture where the capacitor is located.
Notice that in this picture I have already took the bad capacitor out and replaced with two small cords to reach the bottom and test the new capacitor.
To reach this place is not fast, several layers of plastic and metal must be removed, but is not a hard task to take the capacitor out and replace it for another.
It works just great! Now it is back on track with awesome image.
2answers
Intermittent lamp turn off
I was told by the repair service to unplug the power cord for about 5min. This resets the internal computer. I think this helps but does not cure the cause. Good luck.
1helpful
2answers
SONY GRAND WEGA
I have a KDF60XS955. When I power it on, the fan comes on, the standby light flashes green several times, the lamp comes on and the standby light goes to solid green. This lasts for less than 5 seconds then the lamp goes out, followed by ~30 green standby flashes, the lamp coming on with the solid green standby light for about 5 seconds then shuts off the lamp again. I can hear/feel the fan running the enitre time. This cycle continues endlessly. Please help!
No lamp
whats your location, The power supply is faulty, but fairly easily repaired, if you send it to me, I will sort it out
Orange light on lamp icon on Optoma EP732H Projector
This same thing happened to me, I removed the bulb and put it back in, it reset something and I was able to use the projector again.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
