Replace the Lamp P/N 915PO20010 if it has never been replaced.
Mats Electronics has them for $99.00 1-800-628-1118
Once the status light blinks 3 times, this is an indication that
there's a problem with the lamp. The lamp may need a replacement.
If you replace the lamp, but get the same problem, check the inverter board.
If you're not sure where the inverter board is, then you may need to contact a pro for your safety.
Good luck and have a good evening!
I have replaced the lamp. I have 2 of these
WD-52327 TV's and I swapped the lamps. Lamp is fine. The Owners guide in the Troubleshooting section Page 66 says:
Problem - Lamp indicator light is a constant red.
Possible Solution - Turn the TV off for at least 2 minutes. Turn back on. If light is still
red, the lamp has failed, replace it. See Appendix F for lamp
replacement information.
Problem - Status indicator light is a constant/flashing red.
Possible Solution - Service is required. Contact your dealer or a Mitsubishi Authorized
Service Center to arrange for a service evaluation.
I also read it
could be a possible lamp fan issue. Is there a way to get codes from the
WD-52327?
Are you suggesting I purchase a new converter board? Is there somewhere I can get a drawing/picture to locate the converter
board?
Correction. I see you said inverter board not converter board.
I found the service manual and was able to get the ERROR CODES. I am getting 3 flashes a pause and then 6 flashes which is error code 36. The code is:
36 Light Engine (DMD or LAMP Fan stopped)
Suggestion?
I found the service manual and was able to get the ERROR CODES. I am getting 3 flashes a pause and then 6 flashes, which is error code 36. The error code description is:
Suggestion?
