Panasonic CT-27SL14 27" TV Logo
Posted on Feb 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Panasonic CT-27SL14 problem: There is band across the top 3 inches of the screen consisting of multiple thin horizontal lines of about an eighth of an inch wide evenly spaced. The lines appear to be inverted images of the actual image that should be appearing within this three inch band at the top of the screen. The problem is visible for both cable TV input through the coaxial input as well as DVD input through the AV inputs.
Anonymous
Level 3:
Genius:
  • Master 1,274 Answers
  • Posted on Feb 14, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1274
Questions
0
Helped
315760
Points
3479
Horiz.output IC going bad,need to replace it
  • mrvanwinkles Nov 16, 2011
    Nov 2011
    Have similar problem on a Panasonic Tau model CT-27SL15.
    It's a 27" CRT TV manufactured around 2005.
    Found a service manual online w/schematics and board layouts.
    Panasonic Service Manualhttp://dl.dropbox.com/u/35219914/PANASON...
    See pg 25 (of 42) - Deflection Schematic Diagram (Main PCB)
    Finding the actual bad component(s) may not be so easy.
    Anyway ... just wanted to add this comment.
A horizontal band of green and red lines across the screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
2helpful
Our tv, a Panasonic # CT-36D11E/CT-36D11 only shows a horizontal thin line across the screen. The sound is fine - any ideas? Is it time to replace or could it be repaired cheaply?
Resolder the vertical IC and replace those capacitors near and next to your vertical IC. If the horizontal line still appears, you may have to replace the IC. Thanks for asking and be caredful!
White lines across top of screen
Need to replace vertical capacitor at vertical Ic.Leaky capacitor.
Have Panasonic TH-50PX60U HD Plasma. Purchased
Filter capacitors (more than 1) in the main power supply
1helpful
Panasonic CT-27L8SG displays gray screen and white hoizontal line
Is it still under warranty?
If not I would find a good TV Service Shop and have them check out the power supply as there more than likely a 'Capacitor' much like a battery that is going bad.
Blessings,
A/V Media Guy
I have a Dell 17" LCD monitor with a horizontal band.
You would better served replacing monitor you can buy one for about $100-$120 dell if you lie has one for $99
2helpful
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
3answers
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
