Fairly new machine (Jura ENA 5)...suddenly the professional Cappuccino frother isn't making foam and the milk isn't very hot. Tried cleaning it even though pretty new and not dirty...didn't work.
SOURCE: Steamer and milk frother not working
This sounds like one of several problems:
1. Does any indicator light come on? If there is one and it doesn't you either have a bad thermostat (size of a dime/1/4 inch thick) black item with two wires attached to the chamber or a bad heater. Check both with an ohm meter...Resistance of any kind across the terminals means okay.
2. Could be the switch. Same kind of test.
3. If you've got a steam leak, deal with that...new cap or valve.
Make sure all wire fasters are clean and bright. If screwed down, make sure they are tight. Cycle each connector off and on to clean them.
Remember: always work on your unit with it unplugged. You may need torx screwdrivers to open this unit. Any hardware store will have sets of these items.
SOURCE: THE NESPRESSO MILK FROTHER HAS STOPPED FROTHING
I contacted Nespresso who may well replace the item
SOURCE: My Nespresso milk frother did not come with
they make one that has the option of frothing milk hot or cold. Blue light is cold. Red light is hot. The red light will always heat the milk. To get to the blue light, you need to hit the button twice.( First will go to red)
SOURCE: Lost my Nespresso Aeroccino Milk Frother Hot Milk Whisk
Call Nespresso customer service at 800-562-1465. Replacement set of 2 wisks were $2.95 + shipping
SOURCE: The milk in the frother
the frother should have come wit two attachments a coiled one and a paddle the coil one is for frothing fill frother to bottom mark or slightly lower.hope this helps let me know how you went
