Installed the RTH2300 but have a problem because the heater will continue going over the programed temperature...ex: programed at 70 F and will continue till going pass 82 F which makes the house too hot...how can it be set up so that the heater will turn off once it reaches 70 F and if the temperture drops below 70 F it will turn back on to reach till 70 F only...thank you
At the thermostat you have a small tolerance (most have 5% + or -) few degrees is not a problem ex...70F= 21C and 82F=27C this diference is inertial, you can set a lower temperature(ex...60 F to reach 72 F) the problem is if the temperature grow and never stop until the saftey thermostat stop the heating.also is posible to have a broken thermostat(work thermostat) and in this case it must be changed whit new one or the teperature probe is plced in a wrong place.
