How do I reset the Parental Control. I cannot remember the password originally used in setting the VCHIP.
trying to change parental controls
Good day.
Try to press power up button, channel up and volume minus at the same time. This should resolve your problem.
chris
I just bought a used Sharp 27F630 tv and the V-Chip lock is set. Any generic code I try doesn't work and I have attempted to reset it but nothing seems to work. Any help would be appreciated.
SOURCE: Reset Parental Control
There you go:
1) Hit [MENU]. Press [CH up / down] to select ?V-CHIP SET UP?, then hit [VOL up].
2)
Enter 4-digit access code with the Number buttons. If you have not set
up your personal access code, enter 0000 (default access code).
SOURCE: RESET V CHIP PASSWORD ON SHARP 13 INCH TV 13L-M100B
When the message "INPUT SECRET NO." appears, press the Ch UP and Ch DOWN keys ON THE TV SET (Not the remote) until the message disappears. Then press "MENU" two times on the remote to exit. I have a soft copy PDF file for 13L-M100B set. Send me your email to me at [email protected] and I can send it to you.
SOURCE: 27inch tv serial# 27r410T
Press vol-on tv& child lock on Remote together. Press mode on Remote using channel +/- to select child lock select new pin press mode E
SOURCE: Parental Control V chip has been activated.
on my Sharp 36R-s400. Go to menu , then parental control. When dispaly asks for secret number,
press and hold volume up and channel down simultaneously until message is cleared.
This turns off parental control and clears the password.
I have a Sharp tv 27" about 5 years old and i can't get rid of the parental control and i can't remember it it keeps saying v-chip activired
