Is there a way to have handset (M7208 model) ringer turned off so phone does not ring during a meeting?
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
My phone does not ring and the speaker does not work now. The line light up and flash but it is like the external speaker is turned off
