Texas Instruments BA-II Plus Calculator Logo
Posted on Feb 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
BAII Plus TVM Applications
I am trying to figure out how to enter the following problem, can someone please help? Thank you.
You decide to replace the existing roof on your house for a cost of $25,000. You decide to save $1,200 per month in an account that pays 4 percent annual interest, compounded monthly. In how many months would you have enough saved in the account to purchase a new roof?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Texas Instru... Master 102,366 Answers
  • Posted on Feb 19, 2011
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10443202
Points
622693
2nd [CLR TVM] (clears any previous results)
4 I/Y (4% interest rate)
1 2 0 0 +/- ($1200 monthly payment, negative because you're paying out the amount)
2 5 0 0 0 FV (desired value, positive because you'll be receiving the amount)
CPT N (compute the number of payments)
8helpful
My BA II plus professional showing wrong answer while computing "N" during TVM calculation
Make sure you have P/Y set to 1 and BGN/END set to END. With those settings, pressing 9 I/Y 9 2 0 FV 1 0 0 +/- PMT CPT N should produce 7.00 .
Will someone please walk me through the steps to calculate a mortgage payment on the BAII PLUS TEXAS INSTRUMENT. Please be specific. Thanks.
For a thirty-year, $100,000 mortgage at 8% annually, compute the monthly payment:
2nd [CLR TVM] ( clear the time value of money registers )
3 0 * 1 2 N ( thirty years at twelve payments per year )
8 I/Y ( 8% annual interest )
1 0 0 0 0 0 PV ( $100,000 mortgage )
CPT PMT ( compute payment )
You should see -733.76. The negative indicates payment, the amount is $733.76.
I would like step by step instructions on how to solve a simple TVM equation. i.e. I invest a lump sume of $2400 in an investment that returns 6% annually. How much will the investment be worth after ...
GOOD QUESTION, Patweetyp...
I've got you covered.
Seeing how it's been three weeks since you posted this there's a chance you've already gotten your answer, but let me go ahead solve this for those out there who may have had the same problem.
Background: There are FIVE TVM Keys; and as you would assume, you MUST input FOUR of them in order for the BA II Plus to solve for the fifth. Now let's get down to business.
1. Hit CLR TVM. [This is just a cleanup maneuver]
1a. Hit ENTER [yes, BA II Plus always needs to be told to store the value, ALWAYS]
2. Type in -2400
3. Hit PV [Since you are investing money at time 0, your present value is negative 2400]
3a. Hit ENTER
4. Type 6
5. Hit I/Y [Your annually compounded interest rate is 6 percent]
5a. Hit ENTER
6. Type 0
7. Hit PMT [you do not have any recurring deposits*]
7a. Hit ENTER
8. Type 1
9. Hit N [there is one year until expiration/liquidation/termination]
9a. Hit ENTER
10. Hit CPT
11. Hit FV [this is your ANSWER = 2544]
----- From here, all you would need to do is change N in order to get your other answers (5 years, 10 years, etc) ----
*If your calculation does not require a recurring payment then you really just have a basic equation of value which would be solved faster by hand. (IE, 2400*(1.06)^1=FV=2544).
You'll notice that I underlined "annually compounded" as well as "one year". The reason for this is because you ALWAYS need your interest term to match your time interval. For instance, if you had monthly payments of which you wanted the year-end total you would need a monthly effective interest rate, and N would be 12.
Okay, I hope that helped. The BAII Plus is the best calculator for time-value-money calculations I've come across. When things get more advanced, you will start using the amortization table which cannot be found in any other TI Calculator (from what I know). TVM is perfect for annuities, mortgages, loans, bonds, and more.
[email protected] for more questions.
TEXAS INSTRUMENTS = 1-800-TI-CARES...they are friendly.
2helpful
Everytime I input a negative sign in the PV figure in the tvm solver I get syntax error
Use the (-) key to the right of the decimal point key instead of the - key to the right of the 6 key to enter negative values.
5helpful
I have a Texas Instruments BAII Plus Professional Calculator. In the course I'm in, I need to know how to calculate the following formula = 1 + 3.3 log (n) The problem is that I can't figure out how to...
Pressing 2 0 0 LN = will give you the natural logarithm of 200. If you need the common (base 10) logarithm, divide the result by the log of 10.
( 2 0 0 LN ) / ( 1 0 LN ) =
will give you the common log of 200.
3helpful
How to calculate weighted standard deviation using ti baII plus?
Easy,
2nd>7 (DATA)
X01= put the first figure then ENTER
Down arrow two times
X02= put the second figure then ENTER
Down arrow two times .. and so on
till the list finished
press 2nd>8 (STAT)
down arrow
and find your stastics
ENJOY
I am using Texas BAII Plus. The problem is when I try to calculate the NPV, N, PV,PMT, FY. it does not provide the right figure. It was ok until this morning. I think I might press something wrong....
Check the BEGIN/END setting (2nd [BGN]) and the number of payments per year (2nd [P/Y]). If these are set correctly, could you post the problem you're trying to solve, giving both your results and the expected results?
What buttons do I push in what order to figure compound interset. if I start with$15,000.00 at 6% interset for 25 years. I am on a texas instrument ba 2 plus
If the interest is compounded monthly:
2nd [CLR TVM] (clear any existing results)
1 5 0 0 0 _/- PV (present value, negative because you're paying it out)
6 I/Y (annual interest rate)
25 2nd [*P/Y] N (25 years)
CPT FV (compute future value, see 66,974.55)
If the interest is compounded annually:
2nd [P/Y] 1 ENTER 2nd [QUIT] (one compounding period per year)
25 N (25 years)
CPT FV (compute future value, see 64,378.96)
3answers
How do I calculate a mortgage payment?
If $100,000.00 loan: enter 100000. in pv, if interest rate is 5%, enter 5 divided by 12 = %i if 30 year mortgage, enter 360 N enter 2nd PMT to get monthly principle and interest. You may have already solved this problem.
4helpful
How do I get to the tvm function on a TI-83 plus calculator?
Press the APPS key to bring up the Applications menu. Press 1 to select "Finance..." Press 1 to select "TVM Solver..."
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
