I have a new vaillant combi, It has a timer clock, the instructions do not say how to work it, can you help? How do I know what time the clock is at. It has a 12 hour inner dial and 24 outer with no obvious relationship.Which way do I slide the little widgets around outside to turn heating on?
The machine is a vaillant ecotech 831 not the product named below. I only used that to make progress as my machine not named
SOURCE: vaillant ecotech plus f75 code not firing up
F75 is telling you that the pcb has not recognised the slight increase in pressure that is created when the pump kicks in. I hate to say this, but it is a known issue with the ecotec plus range. Usually cured by replacing the sensor (old ones orange) in the bottom left of the boiler. New versions are now black. Can also be caused by muck in the sensor due to poor flushing when the system was installed.
