Posted on Feb 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I remove drawers 1 and 2 from Bizhub C200 - am getting error code C0204
Ben
Level 2:
  • Expert 108 Answers
  • Posted on May 20, 2010
Ben
Expert
Level 2:
Answers
108
Questions
0
Helped
89420
Points
277
Pull out the trays, locate the metal tab on the copier frame that is held in with one screw. Remove the screw and angle the tray out.
Konica Minolta BizHub 4050 A4 Mono Laser Multifunction Printer. How do I clear code c3423 in Konica 4050 please?
Question edited for a lot more clarity.
Its a fuser code. To reset it the code and to get it work again. Follow these steps:1) Turn the main power off ( the switch behind the toner door )2) Hold down the Utility button while you turn the machine back on.
Jul 12, 2017
I am getting an error code of c - 3423 on my Konica Minolta ...
JustAnswer https://www.justanswer.com > computer > ajjia-getting-...
Konica-Minolta bizhub 4050 - Error Code
PrintCopy .info https://printcopy.info > code=3423-121 Konica-Minolta bizhub 4050 · Code: 3423-121.31 · Description: Fuser warm-up trouble. Fuser is too hot. Global overtemp check. · Causes: Controller board (CTLB) • ...
Error Codes > Konica-Minolta > bizhub C353 > Code C3423
PrintCopy .info https://printcopy.info > code=C3423 Code: C3423 · Description: Fusing heaters trouble (pressurizing side) · Remedy: 1 Check the fusing unit for correct installation (whether it is secured in ...
Error Code Konica Minolta C200 error 3423
Copytechnet https://www.copytechnet.com > ... > Konica Minolta Sep 4, 2016 - If you have another fuser try that. Its a low temp condition from the pressure roller. Does the fuser heat up at all after a trouble reset?
KM Bizhub 283 code3423 ?? - Copytechnet
Jul 21, 2016
C4050i Error Code C8403 - Copytechnet
Jun 16, 2023
Bizhub 4050 originals throu jamming - Copytechnet
Jan 7, 2020
Bizhub 4050 Prompt A Trouble Code E301(000.00)
Mar 22, 2021
More results from www.copytechnet.com
Error code c0204
PULL out the second tray remove any and all paper from behind the draw also REMOVE all the STORED paper on the left hand side of the draw that is not a storage area. Storage draw is used. The space is for if you decide to 11x17 paper
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
C0204 error
Remove the second draw and remove the paper from behind it. Then remove the extra paper in the second draw that is sitting on the left hand side that is not A STORAGE location . It is for 11x17 paper.
2helpful
Need help w/ bizhub c350< error code is c-0204
error code c0204 means the yellow drum unit corona has failed the drum unit needs to be replaced this unit may also be called an image unit
8helpful
2answers
On the bizhub C550 an error code C0204..... won't let me use paper tray 2
Two things 1) check to see if there is paper in the back of the of the tray where it meets the back wall (that would prevent the paper tray from rising. 2) there is an upper limit sensor on the paper feed (thats where the rollers are) so check to see if any bits of paper blocking the sensors. If you find it, reset the machine and it will see the tray.
4helpful
Bizhub 200 printer
Tray two elevator motor failure. Make sure you dont have anything sitting under the trays and also make sure the trays are level
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
