Yes, You can buy another screen for Your mitsubishi television, You can get it from any part dealer store, also, You can get it from someone whose television is having a different problem than a faulty screen. There are some television that develop other kinds of fault, therefore, they are moved to stores where they can be disassembled and sold in parts.
Hope this information helped. Thank You for using FixYa!!!
That would be the CRT Board to Red Tube,Mats Electronics did have some CRT boards $9.95
1-800-628-1118
Encompass Parts Distribution might have them 1-800-638-3328
i had the same problem. im sorry to say that you are out of luck and you tv is on the way out. i had the same problem and spend $100's of dollars to have people come and try and fix it to no luck. sorry
THERE ARE 2 CURRENT LIMITERS 1 OHM OR SOLIDER IN FUSES FOR + & - SUPPLY THEY FEED THE CONVERGENCE IC'S YOU NEED TO VERIFY YOU HAVE YOUR POWER SOURCE TO THESE. ALSO A LOSS OF VERTICAL DEFLECTION WILL CAUSE THIS.
convergance amps ic's shorted you will need to replace them or have it done along with the 2 resistor that will have burnt not a bad job about 150 to 200 dollar job
If the picture looks like a 3D then you have a convergence failure.
I would suggest to visuallyinspect the STKIcs for dry or crystallized solder joints.
IC8C01 - STK392-110 IC8C02 - STK392-110
This model has several caps. on the power supply voltages such as the 5v, 9v and 12 v lines that begin to dry out and open and such problems begin to manifest themselves. Most likely this problem will continue to get worse and worse. As far as burned in images there is nothing that can be done short of replaceing all three picture tube and that is very expensive and this unit is to old to consider a 1000.00 repair.
