SOURCE: Fridgidaire 7 cycle - older model top loading washing machine wont drain
could be a stuck gear box. motor trying to turn it on the reverse rotation for spinning. it could be the motor that hums. or the belt could just be loose.
inspect the belt and see if it is loose and adjust it if necessary.
tnx 4 using fixya,
drcool
SOURCE: Error Code E23
Hello welcome to Fixya
E23 means
The drain pump relay on the control board has failed.
Fix: Replace control board or wire!
you can see schematics and diagrams at the site below, and order parts from them if you want.
Or call service!
http://www.pcappliancerepair.com/model-display.php
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
SOURCE: Frigidaire Washing Machine Model # GLTF1670AS0
back bearings defective,,,should sound like train coming down on track..
SOURCE: Frigidaire Washing Machine Model # GLTF1670AS0 Makes very loud
if the noise is really loud in the final spin your bearing are starting to go out your washer needs to be rebuilt but it will be cheaper to go buy a new one
SOURCE: washer will not start washing cycle. Machine hums like the dryer
Check the drain for clog. If the drain is dirty, the washer won't fill, rinse, or drain.
