Televison & Video Logo
Posted on Feb 25, 2008
LCD TV - RED LINE
There is a thin red vertical line straight down the center of the tv screen.
  • 4 more comments
  • Anonymous Mar 07, 2008
    I have a thin red line running down my LCD TV. How do you fix this?
  • BajanBuddah Jul 03, 2008
    i have the same problem...thin red line down the center of my polaroid 32" lcd
  • Anonymous Jan 03, 2009
    Same problem on my 32" tv. only 1 pixel wide. Sometimes changes color to green. Sometimes goes away completely.
  • Anonymous Feb 22, 2009
    same problem on my toshiba 46 inch only bout 6 months old comes and goes.lucky i got cover engineers on his way next week.
  • Anonymous Mar 15, 2009
    I have the same problem on my VIZIO tv which is only about 6 monhs old.
  • Anonymous May 21, 2013
    no its white sharp line one intch distance
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 07, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2743
Points
I have a thin red vertical line on the left side of my Philips LCD TV
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
2answers
Vertical green line
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
Vertical red line
Put in a warranty claim asap.
Sound only w/1 straight red line accross the middle of the screen
try to replace the vertical ic and resolder the vertical section.
There is a vertical red line that runs down the screen on our Sanyo TV. It is just a thin line but it is annoying because you know it is there. Any suggestions?
thin lines are associated with the connection of the pixels on the screen in the grid. If its under warranty get it fixed before expiry as its not a cheap fix.
Red lines are not convergence problems they are component problems so you cant adjust it out
4helpful
Red vertical line down right side of the screen
hi
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use robber
Place the rubber on the top of TCP
Gently close back the top casing
Good luck...
4helpful
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Thin red vertical line on sanyo lcd-37xr1
Sounds like your display panel is going out. Has the tv been droped, or hit by anything? You should call your customer service number to confirm.
1helpful
50" LG Plasma - Thin red vertical line in middle of screen
I work for a auth LG service center and each time I have had this symptom we had to either change what called the T_CON control board or the Plasma display panel itself. You need to cocntact LG @ 800-253-0000 report your problem and they will find a service center in your area you should have 1 year warranty parts and labor.
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
