Tv won't turn on. Just get a blinking red light in lower left corner
Unplug the television...wait 10 seconds and then plug back in....if you listen carefully after 5-10 seconds you will hear a click sound (the same sound that you hear when you turn on or off) ...once you have heard it, turn the TV on again using the remote. Do not turn on until you hear the click. If this does not work, try again but turn the TV on again before you hear the click. I dont know why it happens but it is as if the TV gets confused as to whether its supposed to be on or off. Most of the time, the solution is to turn it on after the click so I would always try that first.
First make sure to hit the menu button on the TV's remote
and if nothing is there then friend while the set is on turn a bright
flashlight on and shine at angle into the set push the TV menu button if
you can see a image then your back light is not working.
