Sony KDF-E60A20 60 in. LCD HDTV Logo
Posted on Feb 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Win i turn the tv on the red light comes on and i can hear the tv like its comeing on but the green light comes on and cuts the tv off but it comes back on but it does the same thing
Anonymous
Level 2:
  • Expert 110 Answers
  • Posted on Feb 14, 2010
Anonymous
Expert
Level 2:
Answers
110
Questions
Helped
31137
Points
287
Your lamp could be burnt out. The tv will keep retrying to start for a few times then will shut down. remove the lamp and see if it looks burnt. When you replace it you will also have to reset the lamp timer. check your manual to see how to reset.
4helpful
TV WONT COME ON AND THE LIGHT KEEPS FLASHIN RED AN GREEN ON THE STANDBY BUTTON
  1. If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
  2. If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
  3. If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
  4. When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
  5. If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
Read more: How to Troubleshoot a Sony Grand Wega ' eHow.com http://www.ehow.com/how_5243554_troubleshoot-sony-grand-wega.html#ixzz1EoY37gpC
4helpful
3answers
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
TV won't screen won't come on. You can hear it
Are you getting a soild red light and a blinking green, or both green and red blinking, that indicates your blub is toast. Time for a new lamp, I'm in the process of doing just that as mine bit the dust this morning. Up here in the great white North the blub costs $220.00. I your lucky and your down South you will pay about half that.
I've had this set since 05 and I am on my second lamp Toshiba paid for the first one not it's my turn, great set otherwise.
When attempt to turn my tv on, instead of the little green light
you will need a schematic for that set but there's a capapictor inte the power supply and possbily the bridge rectifier as well that have cut a current spike which is very common in many t.v.'s they will have to be tested and changed also the capacitors put in those sets in the beggning are below specs due to line voltages and current spikes that occur when the t.v. is turned on and off
5helpful
3answers
Why cant i get my tv to turn on ?
just worked on one of these, same problem, found a bad capacitor,1000uf 25volt, in power supply module.
When turning on the TV the green light on the front does not come on. You hear a click and then about ten seconds later you hear another click but the tv never comes on.
What light do you get, green blinking, red blinking, yellow steady light or yellow blinking light. The led lights will tell what is wrong with your tv.
3answers
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
