Question about SkyScan 86709 Atomic Wall Clock
AI can't figure out how to set the atomic clock
I can't figure out how to set the atomic clock for the tempeture indoor and outdoor I lost my directions I have a Sky scam atomic clock with alarm
  • 714 Answers
This clock will set it's self in a 24 hour time frame. You need only set the time zone your in.
If it does not correct it;s self change walls and location in your house.
The transmitter is located in Fort Collins, Colorado. this station transmits the time codes and is best received at night.
Hope this tip helps.
R/
David
Posted on Feb 15, 2010
SOURCE:
Taylor 1497 digital indoor outdoor thermometer atomic time won't set.
The setting controls can become finicky over time. You may have to hold the button depressed for awhile to get the clock to enter the setting state.
Sep 03, 2018 | Home
Replacement Outdoor Temperature Sensor for Atomic Clock
Search the manufacturers website and ebay. It may require a little time and effort.
Jan 02, 2018 | Home
Skyscan atomic clock problem
Look carefully at the back of your clock for a reset button. The temp may have encountered a problem and stopped working. Also, be sure the battery is fresh. Hope this helps.
May 31, 2014 | SkyScan 86709 Atomic Wall Clock
I have a Sio/Scan Atomic Clock that gives time, indoor and outdoor temp. I have lost the instruction manuel and cannot set time or date since I changed batteries. CN5 V00 U Can you help me?
The Sio/Scan Atomic clocks should automatically set the time and date.
Place the clock in a window facing towards Colorado and give it 24 hrs to update
If that fails here's the web site for them:
http://www.skyscaninfo.com/content/manuals.html
Jan 03, 2011 | Vacuums
My oregon scientific indoor outdoor weather station with atomic clock just stopped picking up the outdoor readings, it won't switch to that channel any longer. tried removing and reinstalling the battery,...
I had the same problem, Since the outside temp wouldn't read, I figured it was the outside unit batteries. Went through half a dozen AAA batteries and wouldn't read. It was the indoor unit. Had the same bats I installed 3 years ago. DUH! Replaced the AAA, and all was well. When the inside batteries die out, it has just enough juice to read indoor temp, but not enought to sense exterior signal.
Oct 20, 2010 | Oregon Scientific Wireless IndoorOutdoor...
3m precision clock lost instructions
HOLD SET BUTTON UNTIL ITEM YOU WANT TO CHANGE FLASHES. USE + AND - BUTTONS TO CHANGE ITEM . PUSH SET TILL IT RUNS ON.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/thomas_6b90afb985d8f4bd
Oct 25, 2008 | SkyScan 86742 Digital Atomic Wall Clock
3M Precision Digital Atomic Wall / Desk Clock with Indoor & Outdoor Temperature and Alarm will not display outdoor temp, i have replaced batteries, outdoor sensor is transmitting, does not appear to...
After replacing the transmitter batteries several times, I tried replacing the clock batteries. They must have been getting low. Once I put in new batteries in the clock it worked fine. Good Luck.
Aug 30, 2008 | SkyScan 86742 Digital Atomic Wall Clock
Manual Information/Owner Guide
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
FixerUpper
Feb 02, 2008 | SkyScan 86709 Atomic Wall Clock
SkyScan 86709 Atomic Wall Clock Logo
1,447 people viewed this question
Top SkyScan Home Experts
Dave Robertson
Level 1 Expert
Are you a SkyScan Home Expert? Answer questions, earn points and help others
