NEC Mitsubishi MGE 4000 Generator ROU Recoil Starter-Voltage Regulation:AVR. Fr Logo
Posted on Feb 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I have it on it stays on high idle speed. When I push the auto idle it will not change the speed to normal. It idles at high speed all time.
Anonymous
Level 3:
  • Master 760 Answers
  • Posted on Jul 19, 2010
Anonymous
Master
Level 3:
Answers
760
Questions
0
Helped
491057
Points
2276
If you have anything plugged into the generator, consuming any electric, it will run at high. It must run at high speed to generate 120V. It will only idle if your turn off the load.
How do I decrease idle speed?
The higher idle speed is part of the "cold start" sequence. It is controlled by the thermostat and a temperature sensor. You may need to change them both for faster action.
My van is idle high i cleaned the throttle boady and it idle down the a few hours later its high idle again why i replaced two sensor and still idle high
Hi Alexandra, Im AL the owner of Big As Auto Repair
There are several things that can cause high idle, but the 2 most common problems are as follows.
(1) You could have a vacuum leak somewhere on the engine. Here is how to check for that issue. Here's what I want you to do: Buy a can of CARB Cleaner and while the engine is running spray around the Intake Manifold, the manifold is the thing the throttle body sit on. Also spray around all the vacuum line as well. If while spraying there is a change in the idle speed then you have found your leak. If there is no change then move on to step 2.
(2) Sometimes when you have a high mileage vehicle parts begin to ware out or can also begin to stick in place. Here something you can check. Idle Air Control Motors can start sticking from corrosion build up and can cause a high idle issue. Here what I want you to do. Start the engine and let it idle, while its idling I want you to tap on the Idle Air Control Motor If it idles down to normal idle speed replace the motor. The motor mounts onto the throttle body and most of them are round. Once you replace it and start the engine you'll notice that its idling real high, :This Is Normal, just let it idle until the engine controller resets the idle speed to normal.
Hope this helps and should you need further help please visit my auto repair website. http://www.bigasautorepair.com/
I have a 98 mer villeger if the car is on drive and i step on the brakes with the air codition on the car keeps pushing forward
Normally the engine has to idle faster because of the extra load of the brake lights when you press on the brakes.. Sounds like your idle speed is a little high. Have someone set your idle speed properly.
Hope this helps you
this is free help...Please take time to rate me
2helpful
Idle is high after changing the timing belt
Replace the idle speed control valve.Very common on fords this fails.And what you are telling me are the same symtoms.Good luck m8.
1helpful
2answers
Engine Idle speed
Yes that is most likely normal for your car. But there you could be other factors playing into the potential high idle, for example if your timing is off the computer could be compensating by advancing spark. When was your last tune up done?
4helpful
3answers
I have a 1981 Honda CT110 Trail 2 wheel motorcycle. I have been working on it and everything seems to be working normal except the idle. It will idle normal for a time and the suddenly rev real high. I...
The problem is an air leak leaning the fuel mix. The idle speed starts going up a ramp until it is wide open. The valves no longer seating well is a possible cause as is carb manifold gaskets, rings and a cylinder head not torqued down tight.
4helpful
2answers
Have 1987 nissan sentra wagon 1.6 carb.engine the problem is an idle problem when I start in the morning or when its had time to cool down I depress the accelorator pedel to set the choke and high idle cam...
Check your Ignition timing before anything
check your plugs see what color they are
red or orange means carb is to lean , black
or oil means to rich then you can go from there
and set mixture screws on carb , let me no how you make out .
Fast idle
hi how are you. your auto choke is bad will need to replace.depending on wich one you have it may only be the vacume choke diafram ( high idle cut off). or it is the electric choke
Top NEC Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a NEC Electrical Supply Expert? Answer questions, earn points and help others
