How do you check fluid levels on king kutter tiller and what type of oil goes into the gear boxes 90w or 85-90.
SOURCE: how much gear oil 72'' tiller
In Gearboxes use gear oil (type GL5-85W 140 or Triple Zero
Grease; which can be poured, and has "EP" i.e. "Extreme Pressure" additives.) Fill the gearbox to approximately half-full level.
SOURCE: 4' king kutter makes grinding noise at times
USE SAY A BROOM STICK AND ON THE OUTSIDE ON THE DECK YOU CAN USE IT LIKE A STETHOSCOPE AND PUT IT TO YOUR EAR AND LISTEN TO DIFFERENT SPOTS ON THE DECK TO HELP YOU ZERO IN ON THE CULPRIT .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
SOURCE: I want to paint my King kutter ll gear driven 6 ft
Caterpillar Yellow is about as close as you will come.
