Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Hi i have a husqvarna ride on lawnmower that moves in reverse ok but very slow in forward and the leaver on pushes forward a small amount not fully forward
  • 472 Answers
Sounds like your bely or one of the pulleys are wore out ck the pulleys and ck to see if the belt has sliped off the pulley
Posted on Feb 17, 2010
SOURCE:
My husqvarna riding mower moves very slow in forward what's wrong
Lisa. the brakes may be sticking. see if it pushes easy. if it does it may have a worn out drive belt.
Nov 13, 2016 | Husqvarna Garden
How can I adjust the transmission linkage on a Husqvarna riding mower model LTH145 product # 954-14-00-06?
The Hydro-Gear transmission in this model tractor does not have an adjustment capability. You can either bend or straighten the actuating rod to adjust it in small amounts. However, with no reverse or forward the transmission may be bad. Check the v-belt first. Replace the v-belt if loose or worn. Otherwise you are probably needing a transmission.
May 06, 2015 | Husqvarna Garden
Husqvarna 2754GLS, Hydrostatic forward/reverse pedal will not return to neutral position.
Parts and Diagrams for Husqvarna 2754 GLS 96043004700 2008 01
I suggest following all the safety procedures suggested in the operators manual first!
ENGINE NOT RUNNING,wheels blocked to prevent being run over, check the return spring ref # 161
Apr 12, 2014 | Husqvarna Garden
My Husqvarna Rider 16c wont reverse - first it was slow in reverse then not at all
You need to check the cable, it is a push pull telescopic style so it is possible to get forward and no reverse, if it was a hydro problem you would not get forward or reverse, there is also timing gears on the forward and reverse pedal, you nee to make sure they have not jumped a tooth as this would reduce movement on the cable at the hydro
Feb 12, 2013 | Husqvarna Garden
Husqvarna riding mower modle yth20k46 that move very slow
The link rod from the petal to the transmission straightened out at the rear bend. Take it off and bend it slightly further to make it go forward faster. The 1/2" nut above where the rod connects to the transmission is adjustable to set it where it doesn't move when your foot is off the petal. Loosen it a bit and you can move the petal slightly forward or backward to adjust it. Depending on how much you bent the rod it won't take much adjustment. Re-tighten and try it out. It may take a few tries. Good luck!
Mar 17, 2012 | Husqvarna Garden
Lawnmower will not go forward or in reverse. Brake is not engaged.
Is the lawnmower in transport mode. I know alot are underneath the back and it is a a small handle that when engaged disallows the mower to be put into gear. Let me know if this isnt the problem.
Aug 23, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My huqvana won't go in reverse or forward
if the leaver moves freely but wont move first check belt is on pulley and if so you have sheared off keyway on the pulley on top of drive axle remove pully replace keyway reinstall
Jul 26, 2009 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
Engine runs good and blades turn fine but the lawnmower does not move forward or reverse.
the freewheel control is in the wrong position. push in all the way for mowing. This control is located on the rear of the mower below the seat.
May 16, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Lawnmower will not move in gear with motor running
Hi
Check to see if any oil leaks between rear wheels where the tractor was parked. Also make sure hydrostatic disengage lever, at rear of tractor by hitch, has to be pushed in.
Apr 05, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
John Deere L120 transmission high pitch noise and no forward move
Try jacking the unit up. Start it up and try moving pushing the forward and reverse back and forth and see if it does it then. It sounds like an oil way in the hydrostatic unit has a check valve stuck. Of course make sure that the fluid lever is up. Hope this will help you. donnyb60
Mar 23, 2009 | Garden
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
712 people viewed this question
Top Husqvarna Garden Experts
J. Bradshaw
lnbn1975
Marvin
Marvin
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
