Connect another monitor to the computer. Once you have the display, change the screen resolution and make sure that it's above 1024 x 768.
Then reconnect the problem monitor and see if that will resolve the problem.
Thank you!
May be its a resolution related issue? Did you try flipping through the various HDMI resolutions like 720i, 720p, 1080i and see if it gets the signal? If you haven't done so please do. I am positive that it resolve the issue.
Let me know if it worked.
Sai.
Let me make this a bit more clear. There will be a resolution set on the computer right(ex: 1280*720 being the normal resolution on most computers) This resolution =720p HDMI on the tv. If the resolution on the computer does not match with that on the tv then you will have a blank screen with no signal. Not that your tv does have two resolutions(720p and 1080i)
http://www.fixya.com/support/p1251846-el...
Read the configuration section of the tutorial below, it does mention changing the resolutions if you don't get an image.
Hope this helps,
Sai.
Forgot to post the tutorial
http://en.kioskea.net/faq/228-how-to-con...
- I'm not using HDMI, using VGA
- I didn't see anywhere in the Element menu/setup to change HDMI resolution settings. Did you mean i should change the setting on the monitor or on the PC?
- i changed the display resolution settings on the PC and continue to get "No Signal"
thx
Problem:
Element electronics FLX2211B - VGA Input Not Working
Element electronics FLX2211B - VGA Input Not working I have been using an Element Electronics FLX2211B tv/monitor the past year with no problems - using it primarily as a computer monitor. Yesterday, while using it my daughter accidentally hit input instead of volume. The input changed to Cable. Since then, I haven't been able to get it to show input from PC/VGA in. I have changed the input selector to PC/VGA - the monitor then says No Signal. I have changed cables, computers, turned monitor on/off, etc. and can't get it to recognize signal. Computer/cable works fine on other monitors. When I plug the monitor into the cable tv outlet, it is working fine as a TV (sound/picture). Any thoughts on what may be amiss/how to reset it? thx
Solution #1
Sai.
My response:
Feb 13, 2010
- - I'm not using HDMI, using VGA
thx
same problem using tv works wow switch to vga no signal here is the solution computer settings 1280 by 1024 pixels working rght now. thank you guys
solution computer settings screen resolution 1280 by 1024 pixels it works
