If the antenna is broke, then you should just get a new antenna. If the antenna connector was pulled out of the radio, it is usually fixable.
If the connector is broke off the antenna, it may may be fixable, I would have to see it. If its done wrong, you could hurt the transmit section of the radio.
KC27 Maxon CB need 10 batterys rechargables 1.2 v for 12v total, use the most amperes or miliamperes possible, if you have a charger case or 27-CRDL Cradle for 27-KC you can use 13.8v regulated 5 amps. máx. but need external antenna. When you put a radio in charger case it switch to use external mic, voltage, antenna & speaker. Actually 2500 mAh "AA" battery is very common and cheap. You can charge batterys on to radio case, only need a 200 mAh eliminator at 15v for 6 hours.
