LG WM-2277HW Front Load Washer Logo
Posted on Feb 13, 2010
My Lg washer is showing a code UE and then PF what can I do to fix this problem.
Anonymous
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on Feb 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
8
Questions
0
Helped
10001
Points
12
UE means that the load is unbalanced in my LG. The code PE means that the water sensor is malfunctioning and needs replacing.
1 Related Answer
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on May 20, 2010
SOURCE: LG washer Model # WM1814CW problem code UE
UE=Imbalance error
load too small
appliance tilted
laundry clumped to one side
non distributable object in tub
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
I have an LG washing machine. It has a PF code. Simple things don't fix it
As LG states in troubleshooting section,
If your unit is displaying a "PF" error code, it means you've experienced a power failure. This may occur if the power supply to the washing machine is interrupted during a cycle from a power outage. To fix this, simply restart the washing cycle
LG Washer - Error Code List ' LG USA Support
2helpful
LG top load washer has a 'UE' Error.
Question edited for clarity
An LG washer displaying the UE or uE error code means that the load in the washer is unbalanced. ... When the uE error code is displayed, it means that the washer is trying to resolve the issue. The washer will fill with water to try to balance the load. It will then drain and try to spin again.
Jun 7, 2021
How to Fix the LG Washer UE Error Code - Fleet Appliance
https://fleetappliance.com > News and Tips
2helpful
Code UE
IE: Water level
UE: Imbalance
OE: Drain problem
FE: Overflow
PE: pressure sensor
dE: door error
LE (with a a slash in the
middle of L. Thermister out
CE: Over amping
LE: hall sensor short
bE: Ball sensor loose connection
EE: eeprom out
PF: power failure
Service manuals for LG front loaders
OE code but will not drain and spin
LG Error quick list. Print it and post it near the washer:
IE: Water level
UE: Imbalance
OE: Drain problem
FE: Overflow
PE: pressure sensor
dE: door error
CE: Over amping
EE: eeprom out
PF: power failure
My Freebie manuals and repair notes are HERE
Error code UE on LG Front Loading Washing Maching
this is what i just found on the internet...
With any washing machine, it is vital to ensure that the load is evenly balanced when using a spin cycle. Redistribute washing by adding or removing items to ensure a more balanced load. ... If the door remains locked and the machine is displaying UE error, please run a drain program.5 Jul 2016
My Samsung washing machine is showing a UE code during a spin ...
or try this link..
Error code UE on LG Front Loading Washing Maching Google Search
13helpful
My washer shows UE code
UE code is an "unbalance error". Believe it or not, it is possible to unbalance a front load style washing machine. Usually caused by trying to wash smaller loads where the drum spins to try to distribute the weight evenly. With less laundry, you cannot distribute enough weight evenly around the drum and sometimes will cause an unbalanced load. If your problem is not a simple loading issue, it could be the balance sensor, loose wiring, or possibly the main control board. I hope this helps.
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
