The rear speakers on the Ht WX70 system have not work since. The receiver has been sent off and still nothing works. I have re-hooked up the speakers and reset the wireless according to the manual. The Blue LED light still will not turn on. What else can I do.
With the main unit turned off, press and hold [REMAIN] on the home theater's remote for 4 seconds. (The REMAIN button is directly under the 7 button). Once held down for 4 seconds, the Volume Indicator on the main unit will turn on for 1 second. Release the [REMAIN].
Press the [RESET] on the back of the Wireless Receiver 2-3 times. The Standby/On LED on the front of the Wireless Receiver will blink 3 times
Turn on the main unit. The Link LED on the wireless receiver will light up if process is done correctly. The front of the main unit will no longer say REAR CHK and the rear speakers should now function correctly.
Turn the unit off hit the remain button on the remote then hit the reset on the satellite speaker receiver unit.
That's all there is to it.
I had the same problem. I just repeated the reset process until it worked one time. Have not had any problems with it (unless the dogs unplug it) since.
We have had this system for about three weeks and I have been very pleased with everything except the wireless rear speakeers. I have tried the troubleshooting tip with the "remain" button and the reset button on the speaker.
For someone who is not terribly electronic/computer smart, can you be a bit more specific about this reset procedure. I have tried this procedure several times and get no response. The red light on the speaker blinks when the reset button is pushed but then remains red and the base unit continues to flash "check rear speakers".
Am I supposed to be in a specific setting (HDMI, DVD, AUX, etc.) when this is done. Help Please !!!!!!!
same problem but was solved by MaTTFLaM
Thank you so very much!
reset isn't making the receiving unit blink three times
I've tried the reset process and the rear chk goes off on the receiver but the rear speakers still don't work. Thanks for any help offered!
