We have lost our user manual and need to replace the battery on our Pride Ultimate mobility scooter. How do you access the battery underneath the seat? Seems like the whole seat needs to be removed, but not sure how.
Hi, ok remove the seat by turning it to the left, there is a lever normally on the right side that will allow it be turned round,
once you done that, lift the seat in a upwards motion, the cover should come away by gemerally lifting it, it should be attached by velco underneath,
you should now see two batteries. 40Ah batteries will allow you to go further if the battery Ah is lower, 50ah batteries again will allow you can go even further NOT faster, if you buy the larger AH batteries please make sure the dimensions of the batteries will fit within the scooter battery holders.
Regards
GeWiz.
Testimonial: "Thanks so much for the help. The seat did come off in the end but with difficulty. Batteries now changed OK. Thanks again. "
