Hi, I beleive the error codes are in binary code, anf you need to split the eight "bits" into two 4-bit "bytes". Therefore the 0010 = 2, and the 0111 = 7 (look up binary, or BCD. the various WIKIs shoiuld help). So, I think you had a 27 error, not a 37 (that would have been 0011 0111 (right-most "bit" = 1, next going left would be a 2 if not zero, next left 4, next left 8). This is how computers work with millions of logic gates being either "on" (one), or "off" (zero state bit) decoding all data processed.Hi, I beleive the error codes are in binary code, anf you need to split the eight "bits" into two 4-bit "bytes". Therefore the 0010 = 2, and the 0111 = 7 (look up binary, or BCD. the various WIKIs shoiuld help). So, I think you had a 27 error, not a 37 (that would have been 0011 0111 (right-most "bit" = 1, next going left would be a 2 if not zero, next left 4, next left 8). This is how computers work with millions of logic gates being either "on" (one), or "off" (zero state bit) decoding all data processed.
You can't post conmments that contain an email address.
It sounds like your Fisher and Paykel washing machine is displaying an error code, indicated by the beeping sound, the blinking wrench light, and the Regular and Easy Iron lights being on. The specific meaning of this error code will vary depending on the model of your washing machine, but it likely indicates a problem with the water supply.
The most likely cause of the problem is a clogged inlet hose or inlet valve. The hose that connects the water supply to the washing machine can become clogged with debris, and the inlet valve can become clogged with mineral buildup. To fix this problem, check the inlet hose and valve for any clogs or debris.
Another possible cause could be a malfunctioning pressure switch, which measures the water level in the machine. It could malfunction, causing the device to think that the water level is too low and stopping it from flowing in.
You should consult your washing machine's user manual for the specific error code and troubleshooting steps for your model or contact the manufacturer for further assistance.
It's essential to follow the manufacturer's instructions and guidelines when working on your washing machine and only attempt to repair or service it yourself if you are familiar with the product.
Most possibly be Error code 56,
Is common in 11 series machines & early series 12. Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code, To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
this sounds like the motor controller cant start the motor. I would be looking at the motor controller itself. when it's filling with water, does the bowl go around slowly?
The error code is displayed when its beeping. I don't know the error code, so It can only be three things, Out of balance switch,Lid magnetic reed switch,Or Rotor position sensor,Your error code would help me work out witch one of these are faulty. to work out your error code look at picture below. Add up the lights that are on.
Hi, this is an update on what I found out about the E51 error code from Fisher & Paykel. This code is an error with the internal memory as one of the previous poster's said. Fisher & Paykel Rep said though it wont hurt the function of the machine it should still be replaced because it may effect the compliance information.
Fisher & Paykel GW608U Top loader washing mashine. On power up it will pass the self test, but then it goes to error (single beep every second and lights: green 3rd, 4th green and 7th orange from left are on). Could you advise on the problem please or supply error message codes table. Greatly appreciate your help and looking forward hearing from you
